SOURCE: sony ericsson c905 no network coverage
Hi
Thanks for using FixYa. Please check the sim card first because it might not be making good contact to the prongs. It's not the phone causing the ‘no network coverage’ issue, it's either the sim needs to be removed and wiped off with a soft cotton material and then reinserted or it's the network having problems itself. Also try the sim card in another phone. If it works, then the problem is with the handset. If the sim doesn't work in another handset then contact your network provider to get the sim replaced. If it is still under warranty you'll need to take it back where you purchased it from to get it repaired or replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: no signal . no network coverage . sony ericsson k550i
change FEM
or open shield of FEM and change the RF part
SOURCE: sony ericsson w995 saying no network coverage
Hi mate i had same problem this morning, i was gutted cos i got mine off ebay, so have no guarantee, however i went to se site and updated the softwear, even that there was no update, it re-installed the softwear and wala its working fine, am i ha happy bunny. Hope it works for you? Meurig
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w995?lc=en&cc=pk
SOURCE: sony ericsson w995 saying orignal battery is needed to charge
this is a software glitch
same thing happened to me
you must update your software with latest sony drivers for w995
go to sony ericcson update service
SOURCE: no network coverage sony ericsson w595
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. (type this on the main screen)
hope yougot the solution.
u need to try 3 things in this case
1) make sure ur service is activated , check 4rm it 4rm ur service provider .
2) need to try ur sim in different handset .
3) try to master reset ur phone ..
then try using internet agian...........
