Thomson 26943GE1 Cordless Expansion Handset Logo
Posted on Apr 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thomson 25902 cordless wxpansion handset
I want to buy an expansion handset (part # 25902, I think) for my GE 5.8mhz corded base w/ cordless handsets which is model # 25982EE3-A, but I can't seem to find it on your website. Please direct me to the site where I can order it. Thanks
Genys; All that I need is the website where I can order an extension handset for my GE (Thomson) corsdless telephone. I believe the part # is25902. I don't think that I need a team of elite experts to find the answer. It seems to me that just a plain old helper could do the job. Maybe you could read my original request? And send me the answer?
Marvin
Level 3:
Top Expert:
  • Thomson Master 85,242 Answers
  • Posted on Apr 17, 2017
Marvin
Thomson Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29031615
Points
266281
Sorry we do not have that information here.
4 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jan 09, 2008
SOURCE: Instruction Manual for Thomson phones
http://www.home-electronics.net/ge/pc/IB/27851GE1_IB.pdf
Anonymous
  • Posted on Oct 23, 2009
SOURCE: Model 25865 cordless handsets have hardly readable
mybe der is sum dust on the screan?
Anonymous
  • Posted on Apr 07, 2011
SOURCE: Hello i have a ge 28118 series slim dect
My phone is making a lot of noise and static on in coming call so bad I can't talk. out going I can't make. I put in the number to dial call does not go through ,but I can hear the dial tone. do I need a new battery or is there something wrong with the phone itself.
  • 102366 Answers
  • Posted on Nov 07, 2012
SOURCE: hOW DO YOU REGISTER A Thomson GE 27911FE1-A DECT 6.0 HANDSET TO IT'S BASE
Follow the instructions in the fourth column of the first page of this manual.
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
2helpful
Purchased addt'l handset to work with my CEZAI2998. It has a corded handset in the base and an accessory handset with charger. Needed another accessory handset; purchased EZX290 but can't get it to...
The CEZAI2998 does allow up to a total of 6 handsets, but your issue is that the EZX290 handset is not one that will function with that system. I have listed below the compatible handset models for that Uniden unit and as you can see the EZX290 is not supported. Sorry to be the bearer of bad news, hopefully you can exchange it for a compatible handset. Good luck!!
EJ
Compatible with select Uniden handsets
Including models DCX150, DCX200, DCX210, DCX290, DCX300 and DWX207 for wide-ranging compatibility.
6helpful
2answers
"out of range"
I have a GE DECT 6.0 Digital phone (silver, 2-handset model) and one of the handsets began displaying "Out of Range" and was unresponsive. We've had severe lightning around here in recent days which interfered with the digital tv reception, so I'm pretty sure that's what caused the problem. Here was what worked for me:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
This action re-initiates the transmission between the base unit and the handset.
GE Cordless 25952EE1 A Cordless wont register in base base flashing CL
After talking with Thomson Inc today your best bet is to get rid of the phone. I found out today this phone has a real problem as I see it. I can use my handset on other bases. So that means anyone with this model handset can access your line. Thomson agreed today that this is possible. All I got was a SORRY!
1helpful
Model 29265 trimline phone handset falls from cradle
push the handset hook up and out with your thumb,turn it 180 degrees,and replace it in the slot on the base. Bridrijo D. Howell,Bermuda
1helpful
3answers
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
2answers
Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Top Thomson Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
