Reebok 8000 ES Treadmill Logo
Posted on Jun 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to take apart and move my reebok 8000 es treadmill
Treadmill is too wide for my doorways.
ernesto cuadra
Level 3:
Top Expert:
  • Reebok Master 12,223 Answers
  • Posted on Jun 22, 2012
ernesto cuadra
Reebok Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081144
Points
34431
You to dissasembly read your instruction manual and proceed download from www.fitness.manualsonline. or www.iconservice.com
2 Related Answers
Anonymous
  • 40 Answers
  • Posted on Nov 01, 2009
SOURCE: I have lost my key for the Reebok Treadmill
Any magnet will do. Otherwise order a new one from the manufacturer, other retailer or ebay.
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 23, 2010
SOURCE: how do I take my reebok 8050 ES treadmill apart?
Go to iconservice.com click on manufacturer the model name you will find an owners manual so you can disassemble your unit
Reebok 8000 whine
try to lube the deck belt +rollers bearing front+back+test drive belt motor, and replace if necessary.
However after you lube , the problem persist TIME to replace the old deck belt.
God bless you
1helpful
2answers
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
Hi, my treadmill is 2 months over warranty and does not power on. Any possible solutions?
check fuse(15 amp switch next to power cord connection)
check connections of power cable to switch
3 check power outlet
I purchased a Reebok 8000 ES. After we installed
Your machine should have arrived with the key in it. You could contact the manufacturer at 800.999.3756 or order a key at treadmill key
1helpful
2answers
Taking it apart a reedok performance runner
If the treadmill is a Reebok 8050 they have manual for it at iconservice.com. This compamy manufactures a wide variety of treadmills and the only way for sure to find the correct manual because they have the assembly instructions that canbe useful in the disassembly procedure.
Reebok
  • For questions about parts, service, user's manuals or non-working products for Reebok Home Fitness equipment, please call our Reebok Customer Service Department at 1-877-994-4999.
1helpful
How do I take my reebok 8050 ES treadmill apart?
How do i unfold the reebok 8700 es treadmill? Just moved and have no idea. HELP!
We have a Reebok 8700 treadmill and need to get it downstairs-what is the easiest way to take a small amount apart ?
Get Life Fitness 9700 generation treadmill through doorway
You need to remove the upper console arms/assembly - unbolt the five or six large bolts holding the frame to the base (you will need to remove the motor hood) and unplug the cable from the circuit board that goes up inside the arm to the console (make sure the power is unplugged!) use a 3/4'' ring spanner or socket.
Top Reebok Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
