Hi all, I have have 3,000 songs on a 32GB flash drive (Sandisk) with the Numark Library installed. All the tracks are loaded & play without problems. I have however noticed when a track is playing on either deck & then I search & load another song on the second deck whilst track is playing , I can notice a slight delay or stutter on the track I'm playing. It's is hardly noticable but can be heard. When I loaded another USB flash stick of 8GB, all the songs don't appear to have this problem. Is there something I can do to fix this issue on the larger size flash drive, defragmentation or transferring songs in small folders onto the 32GB USB drive? Cheers
SOURCE: library questions
hey try to down load the numark librarian from the thumb drive that came with ur device. the connect your ipod to the computer. then go to the librarian page and it will show there then ppress on the name that shows up for your ipod and click next or creat library....it will take a while if theres alot of song but if its short it will say done in a few minutes.......then connect it to your idj2 andf press update . you wait alil bit and then you can finally search with your keybord...
SOURCE: I was play music getting
I have the same problem.
I did a reset, waited 10 minutes, and startet the Idj with a usb-stick with music, and it worked. But this problem returnins every time I use the mixer.
Lars
SOURCE: The Cue button on my
This cant be solved by yourself.You need to do continuity testing on the board.This problem
arises due to water fall on the board.Rough use of the Numark or it would have fell down badly.
The circuit board has been shorted out.Have to do correct testing to find the correct IC which is damaged on the board.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
