Question about Dell Vostro 1510 Laptop
Dell vostro 1510 laptop wont turn on....power button does not lite up. sometimes screen is grey when I turn it in on. Suggestions?
    New Friend:
How to give the connection to the on/off switch in motherboard in dell vostro 1510 laptop
Posted on May 23, 2013
SOURCE:
knotbeerdan
  • 413 Answers
SOURCE: Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
Hopefully you can find something helpful on this site. Basically you need to flash or reset your bios now. this site also has some links to remove upgrades. LIke i said i hope this helps.
http://www.user-guides.co.uk/Dell/DellManuals/Dell.asp?keywords=Dell+Vostro+Manual&recor=1
Posted on Dec 29, 2008
NitrusInc
  • 326 Answers
SOURCE: I have problem with my vostro 1510 wreless,
The Dell QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
It is known to glitch when power is removed from the machine while the wireless is in use.
Please let us know if you have any futher questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Posted on Apr 23, 2009
  • 3940 Answers
SOURCE: dell laptop vostro 1510 flashing 9 on the keyboard
That is an indication of either a Video or an LCD failure. If under warranty, contact Dell Tech Support.
If out of warranty, remove all drives, battery, wireless card memory and see if error indications change. If they do, add a ram module back and see if the system posts. If it does, add items back one at a time until you ID the faulty one.
If there no changes, the the motherboard most likely has failed.
You can run the troubleshooter to see if the tool gives you more detailed information
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=04&l=en&s=bsd&journalid=7AF02DEA4AA96B7BE040AE0AB8E13EBB&treeid=2C485ADAA75B367CE040A68F5B285C4D&Query=bm8rcG9zdCtWb3N0cm8=&SystemID=&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false&dl=
Posted on Dec 18, 2009
  • 401 Answers
SOURCE: dell vostro 1000 laptop power problem.
THEREI S A SHORT CIRCUIT IN LAPTOP REMOVE BATTERY AND TRY
Posted on Mar 21, 2010
SOURCE: Dell Vostro 1510 Laptop; cant get anything on the screen
Same thing happened to me.
I stumbled on this link and the solution made sense to me.
http://en.community.dell.com/dell-groups/new-to-community/f/3511/t/19323146.aspx
What I did was to nudge in the Hard drive to make sure it wasn't loose and press down slightly on the processor even though it didnt feel loose.
Worked for me. Though I'd help someone else since someone else 's post helped me.
Posted on Jun 17, 2010
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached.
May 06, 2017 | Dell Vostro 1510 Laptop
Dell vostro 1000 laptop power problem.when you plug in the power supply before its plugged into the computer the green lite is onwhen you plug the adapter into the laptop the light goes out and there...
older vostros usually have a broken dc jack right where the power connector plugs in. otherwise try another ac adapter and also try removing and replacing the battery underneath.
Jan 30, 2018 | Dell Vostro 1000 Laptop
I have dell vostro (1510) and when i turn it on the monitor screen is devided to 2 part and after a few minutes the screen will be Teched.what should i do?
Pressing F8 when you start the computer should get you into safe mode. Once in windows go into your display settings and restore it back.
Apr 11, 2010 | Dell Vostro 1510 Laptop
Turned off Dell Vostro 1510 midway through as I was struggling to remove a DVD, now it wont power up. I get an option to use the repair mode, but that just takes me to a blank screen.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 24, 2010 | Dell Vostro 1500 Notebook
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Mar 20, 2009 | Dell Vostro 1510 Laptop
Dell Vostro 1510 Laptop Logo
536 people viewed this question
Ekse
Clive
Clive
