See this causes:do it with carefully Water-inlet valve defective replace Internal filters clean the filter, otherwise if the machine autocleaning not do it, and proceed in autocleaning Drain valve can be clogged fix it or replace Spray arms clean from debris, and fix it see the diagram Water temperature must be preheated tes the heating element see how to do it Detergent cup see the detergente cup open and fix it.
There is a seal by the push rod that stops the tractor that is leaking...
Here is a tip about how to
get parts for your traveling lawn sprinkler and also a great
article about how traveling lawn sprinklers work.
Traveling
Lawn Sprinklers
heatman101
