C drive crashed due to a virus -- I have ran super antivirus & avast anti virus -- have been in safe mode -- I can't get it bach -- have no rescue disk & can't run system restore
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
hope this helps
SOURCE: hard disk drives are not opening
what you should do, you should find WindowsXP then put in the CD-ROM drive then try to bootfrom the CD-ROM then press anykey,then first opton press enter,then F8 as an agreement then choose repair option by pressing R.then write to us again so that we shouldknow the results.
SOURCE: Not Using 3 Anti Viruses
Suggest you download the free edition of Malwarebytes Anti-Malware instead.
Malwarebytes will wipe out what Avast, AVG, McAfee, Norton, Windows Live One Care, Windows Defender, and a lot of other anti-virus programs, Will Not!
This is info about Malwarebytes on Wikipedia.org,
http://en.wikipedia.org/wiki/Malwarebytes
This is the page for the free download of Malwarebytes,
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
SOURCE: Acer desktop PC will not
download kepreskey rescue disc, and boot off of disc. you will need to set the boot sequence so that it boots off disc first....or flash drive. the download is free, and it works well.
i have the same desktop.
http://support.kaspersky.com/faq/?qid=208282173
The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
. Even if you running anti-virus software, it may be
beneficial to scan your PC with another scanner to check for viruses. No
anti-virus software is 100% perfect at catching everything. Here are a few good
free online virus scanners that you can run to check your PC:
Now, Click on Next and System Restore will start and windows will take a
reboot.
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid=
23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System
Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614
.html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free,
anti-virus products available. One good source to read editor and user reviews,
and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus
software. In addition to the reviews, you can see how many people are
downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html
) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm
l ). Both are very good, and completely free. At present I am using
Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22
39_4-10322935.html ), and it has good ratings, but I have not
personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I
also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h
tml ). Ad-Aware is a free anti-malware, anti-spyware package.
