I get an yahoo messenger.exe while I`m online using messenger, out of no where or specific time frame a gray error window pops up and says YahooMessenger.exe-Application Error. The instruction at 0x7c9116f4 reference memory at 0x0123f3ca. the memory could not be read. I used different numbers for an example. It then asks me to terminate the program. Or it will just close on its own>? Any ideas>?
SOURCE: yahoo messenger
first remove the program from control panel/add remove programs. then download and install this free utility >> http://www.ccleaner.com/ run cleaner and registry. after you're done, reinstall Yahoo Messenger. hope this helps.
SOURCE: yahoo.messenger.exe-Apllication Error
Your Messenger is currupt by some virus.
--- Remove Messenger through control panel
--- Scan your system with good antivirus
--- Clear System Registeries using tools like cCleaner or system mechanic
--- reboot and reinstall messenger
Hope it will work
Thanks
Zulfikar Ali
SOURCE: the application failed to initialize properly
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
SOURCE: "C:\PROGRAM 1\Yahoo\Messenger\YahooMessenger.exe The application has failed
Hello!!!
You can reinstall it easily by following below Steps :
1. Download this installer : http://www.filehippo.com/download_yahoo_messenger/download/120679041d997dc3e015bd0898f8041d/
2. Run the Setup and Install it.
3. Start Yahoo messenger from Desktop.
4. Enjoy..!!!
Hope this Helps..!!!
