Cameras Logo
Hajzimbo Posted on Feb 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you fix my waterproof (scuba) case for ixus 690
Can you fix the waterproof case for an ixus 690 which I use when scuba diving. A tiny plastic nipple which makes contact with the power button has gone AWOL. Can you fix it? Also if I replaced the 960 with the 330 can I use the same waterproof case? Many thanks for your help. Cheers Haj
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Sep 24, 2019
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232944
Points
686
3 Related Answers
Anonymous
  • 9 Answers
  • Posted on Dec 18, 2008
SOURCE: screen reads card cover open.
What model of camera do you have? The plastic "nipple" usually actuates a push switch. If you have the technical ability, you could bypass the switch, but don't try it unless you are really sureof what you are doing.
Anonymous
  • 3006 Answers
  • Posted on May 11, 2010
SOURCE: the on/off button - tiny plastic fulcrum that
Then unless you can fabricate a total replacement part (doesn't have to look good, just functional) then your camera is now junk.
Unfortunately, except for semi-professional models, cameras are simply not designed to be repaired so spare parts support is very poor. Budget models such as yours are really only expected to last a maximum of around three years, some even less. You'll find very few digital cameras of any kind which have not suffered a terminal fault after around six years.
Faults like the one which you have are very unfortunate, but if they were better made then they would cost far more; due to the rapid advance of digital photographic technology there's simply no way that mass consumers will pay more for a gadget which is soon outdated..
  • 102366 Answers
  • Posted on May 12, 2012
SOURCE: is canon ixus 50 is waterproof?or can use underwater?
No, the IXUS 50 is not waterproof, you cannot use it underwater without an underwater housing.
The purge button rubbers have broken its only 15 months old and has been taken care of well after every dive has any one else had this problem and can it be fixed ?
Yes you can get the regulators rebuilt. It is odd that they or it had to be repalced. I would check to see if the warrenty might cover it.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Does the orange panasonic lumix dmc-ts1 go underwater?
Yes, but not very deep. It's specified to be waterproof to three meters (about ten feet). You can use it at the pool or walking/wading along the beach. I wouldn't take one scuba diving.
1helpful
Guidelines to Scuba Regulator Purchase
The scuba regulator is employed in an open-circuit scuba set. Said scuba equipment reduces high air pressure conveyed by the diving cylinder to the first stage and feeds breathable gas to the diver through the second stage's mouthpiece. Also called pressure regulator or demand regulator, the scuba equipment is one of the essentials to diving that determines breathing quality and inhalation effort during the dive. But given the different types of regulators and the pertinent design of its first and second stage components, how should a neophyte diver - or even a seasoned diver at that, choose a scuba regulator that incorporates user adjustment and delivers a venturi-assisted air flow in its features? Consider your diving purpose and frequency. Better yet, take note of the following criteria to guide you in your purchase: 1. The Scuba Regulator's Mouthpiece. Check the specifications if the regulator is outfitted with a patented orthodontic mouthpiece. This implies that it is ergonomically-designed to accommodate an overbite or underbite by the human mouth. An ergonomic mouthpiece helps reduce fatigue in the mouth and jaw area, particularly in the cruise of lower depths and extended dives. 2. User Adjustment Settings. There are optimally-designed scuba regulators that are outfitted with adjustment levers to therefore allow divers to finetune valve settings in order to provide the least possible inhalation effort throughout the dive. One notable scuba equipment is the Aeris AT 400 Pro Regulator that is equipped with an adjustable second stage. 3. Weight of the Scuba Regulator. Visualize yourself on a dive and using just any other type of scuba regulator. Is the regulator bulky to considerably increase drag and cause jaw fatigue or is it buoyant enough for you to carry around with your mouth? Lightweight scuba regulators use polycarbonate thermoplastics for its housing to make the scuba equipment compact, sturdy and corrosion-resistant that makes them fit for extended use. 4. Nitrox Compatibility. This entails an ocular inspection of the cylinder tank (Nitrogen and Oxygen proportions) and scuba regulator (Nitrox compatibility) specifications. As a matter of convention, most regulators are suited for nitrox mixture use out of the box; containing the standard, maximum proportion of 40% Oxygen (in terms of volume) but then again, there are gas mixes supporting leaner proportions of oxygen such as the trimix. Therefore, check if the scuba regulator supports the gas mixture configured for your diving cylinder prior to purchase. 5. No-Contaminant Feature. As much as possible, choose a diving regulator that has been manufactured using Dry Valve Technology (DVT). DVT operates through an automatic valve that prevents contamination of the first stage mechanism to thus prevent regulator flooding and the entry of moisture or dust particles. This likely improves scuba regulator performance and extends its useful life. 6. Air-Sharing Feature. This feature often associated with octopus regulators (used as a spare demand valve or alternate second stage) will prove to be most helpful during diving emergencies such as a free flow or during diver rescues. High performance octopus regulators such as the Aeris Gyro Octopus Regulator are designed lightweight and with air-sharing feature, while sporting an inline swivel for convenience mounting and flexibility
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
5helpful
Scuba mask maintenance
" 1. Use a defogging solution before every dive, even when diving more than once in the same day. This will prevent your scuba mask from fogging during a dive. You can purchase a commercially prepared defogging solution from any reputable scuba diving retailer. Squeeze a drop or two onto the inside lens of your mask and gently rub the solution around to cover the inside completely. Dip your mask briefly into water, swirl the water around the inside of your mask very quickly and empty the water from your mask. A quick rinse will remove any excess defogging solution from the inside of your mask. You do not want to get defogging solution in your eyes, especially while diving, since it can cause stinging and irritation. If you don't want to use a commercially prepared defogging solution you have a defogging solution readily available and it's free, your saliva. Your saliva will prevent your scuba mask from fogging just as well as any commercial defogging solution. The enzymes in your saliva stick to the lens of your mask like a commercial defogging solution and you will never find yourself without a defogger while on a dive. 2. Never lay your scuba mask face-down on any surface. Salt, sand and grit will scratch the lens of your mask. Always place your mask face up when you are not wearing it or if it is not in its hard case. 3. Rinse your scuba mask in clean, freshwater after each dive and dry it thoroughly before storing it in its hard case. After a dive, your mask will be covered in a salty residue and/or dirt. This must be rinsed clean to prevent the silicone on your mask from degrading. Your mask must be completely dry before storing it to ensure the silicone stays clean and odor-free. 4. Always store your scuba mask in its hard case. If your mask did not come with a hard case purchase an after-market hard case. This will protect your mask from dirt and abrasives and protect it while traveling. Always store the case out of direct sunlight. Direct sunlight will break down the silicone after years of exposure. 5. Periodically repeat the toothpaste treatment to keep the lens of your scuba mask clean. A good rinse after each dive helps to keep your mask clean, but to ensure there is no residue or grit left on your scuba mask you must properly clean it on a regular basis."
Scuba Gauges what do I need them for?
"A diver relies on scuba gauges to know three things: 1.-Depth 2.-Air Consumption 3.-Time Depth and Time are vital for nitrogen and air management. A scuba diver needs to know how deep he has been and for how long in order to judge the necessity and length of decompression stops and to calculate residual nitrogen for repetitive dives. The time of a dive is easily tracked using a scuba diving watch and the depth is tracked using a depth gauge. "
2helpful
Scuba boots / booties maintenance
" 1. Rinse your booties in clean, freshwater after each dive and allow them to dry thoroughly before storing. After a div, your booties will be covered in a salty residue and/or dirt. This must be rinsed clean to prevent the neoprene from degrading. Your scuba booties must be completely dry before storing to ensure the neoprene stays clean, odor-free and free of mildew or mold. 2. Scuba bootie zippers should be lubricated occasionally to prevent degradation of the metal or plastic. 3. Always store your scuba booties out of direct sunlight. Direct sunlight will break down the neoprene after years of exposure. 4. Periodically machine or hand-wash your scuba booties. A good rinse after each dive helps to keep your booties clean, but to ensure there is no residue or grit left on your booties you must properly clean them on a regular basis. You can purchase a commercially prepared neoprene shampoo, zipper lubricant/desalter and a neoprene sealant to thoroughly clean and seal your scuba booties. A commercial shampoo and sealant are specifically manufactured to care for your neoprene and is the recommended method for proper maintenance. 5. Any holes in the neoprene on your scuba booties can be fixed using a commercial wet suit cement. "
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
