Detecto Digital Length Measuring Device for table mount or the model 8450 Logo
Posted on Jun 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the function of Detecto Digital Length Measuring Device For Table Mount 8450
Anonymous
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 88 Answers
  • Posted on Jun 21, 2012
Anonymous
Expert
Level 2:
New Friend:
Night Owl:
Answers
88
Questions
0
Helped
21433
Points
222
tip
Measure windows - easily and precisely
I always found it difficult to accurately measure windows with a tape measure, until I put a couple of sticks together. The sticks work great for measuring window widths for window shades or for ordering replacement windows. It is also perfect for finding a minimum width, because nothing in an old house is straight.
For measurements between about 26 and 42 inches you will need two straight pieces of wood approximately 1/4 x 3/4 x 24 inches. Round off one end on both pieces.
You can use a small clamp to lightly hold the pieces together. (Optionally, if you have a router table you can put slots in the two pieces to accomodate a bolt, nut and washers.)
Adjust the two pieces so that their combined length is just a little longer than the space you want to measure, and put only light pressure on the clamp or bolt. Twist the device through the space you are measuring so that the length of the device assumes the exact width you are measuring.
Do this in a couple of places (at the top, middle and botton of the window) to find the minimum width. Then tighten up the bolt (or clamp) just a little so it doesn't slip. Then measure the combined length of your sticks with a tape measure. This is amazingly precise.
How do I alligne the blade to the miter fence on my table saw. delta 10" no.34-670. thanks gregg
Just performed the same task on another brand table saw. un-sungged the bolts holding the table to the saw frame and tapped corners of the table while measuring distance from the mitre slot to the lead and tail of the fully extended saw blade (not from the teeth) calibrated to a perfect 90 degrees position. I figured out how to use a digital miter gauge to measure the distance from the blade to the edge of the mitre slot. You can tap appropriate corners to align.
Note when you are in alignment, re-tighten the bolts a little at a time, measuring and tapping as you go.
May 17, 2017 • Delta Saws
Where can I find owners manual for detecto d220 stainless steel body fat scale online
I couldn't find a manual on the internet either.
You could try these 'resources' though
Visit the detecto official website (I couldn't find the manual there) and use the support tab at the left edge of thar page or find contact details and ask detecto for a manual.
http://www.detecto.com/
I think detecto have a facebook page. Login to facebook and go to https://www.facebook.com/cardinaldetecto/posts/10151307170136769 (I'm not sure that you have to be logged in but I w3as and went straight to that page). It is about problems with a D220 AND HAS CONTACT DETAILS FoR YOUR PROBLEM (from 2013 though)
finally if do get a manual upload it to the fixya manuals collection
11.May.2016
Sawblade is not parallel with fence on delta tablesaw
The Rip fence SHOULD toe out aprox 0.010mm over the length of the rip fence to prevent binding. Adjust using the Rip fence to measuring rail. Should be adjusters there but if its an old saw, you may have to adjust the measuring rail where it meets the saw frame.
Jan 06, 2014 • Delta Saws
Detecto monitor-need op manual to setup
here is a link to a copy of the manual
http://uploading.com/files/QC4JQPNC/8535-M151-O1_(8450_Baby)[1].pdf.html
3answers
Fat percentage question
Some body fat percentage levels are more culturally valued than others, and some are related to better health or improved athletic performance. Ideal percentages are also based on age categories as well. The recommended amount for women is 20-25% and for men is 8–14%. You can find a more detailed body fat percentage chart at your local dietitians and nutritionists, and on the internet.
Top Detecto Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Detecto Measuring Tool and Sensor Expert? Answer questions, earn points and help others
