Flashing red indicates that the battery is non-functioning (at the end of its ability to hold a charge), although as it is a new battery, this would seem a bit odd.
Did you buy the battery new or 2nd hand, was it a genuine Dell battery? My suspicions are that if this is an aftermarket battery and one which was not compatible with the dell, then there might have been some damage done to the laptop, causing the old battery not to charge. I'm assuming you are using a genuine Dell charger
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
SOURCE: my battery light flashes red
Try removing the battery and just use the AC adapter. If the laptop functions normally then you have a problem with the battery charging circuit . Either your battery is defective or the circuit that charges it is defective ( meaning the system board).
