The engine often surges at low speeds.This bike might be running to lean.What to do?
SOURCE: BMW R1150 RT
I love my R1150RT. It is smooth, it has a lot more lug at lower RPM than the older modles (2003 and before models with 1 spark plug). The modifications with 2 spark plugs have cured all the surging. Should you want a smooth, reliable, comfortable and high speed touring bike, I would sauggest this bike is the best.
SOURCE: I have a 85 Honda Shadow vt 500. Engine is surging
did you clean all the jets good sounds like it may be in the jets and needle part of the carbs
SOURCE: 2002 suzuki LS 650 running lean at higher speeds, (off idle)
this prob happens allways in carburated engines that the car or motorcycle is running lean or rich . because the air - fuel mixture ratio is not right . so you should open the carburator and remove the air filter you will find two screws in the lower front section of your caeburator. you can adjust them by a screw driver until your car is smooth
