SOURCE: need instruction manuel for motorokr t505
Chk out this link..
http://safemanuals.com/user-guide-instructions-owner-manual/MOTOROLA/MOTOROKR-%20T505%20BLUETOOTH-H-JTALERTELEFON%20TIL%20BILEN%20MED%20DIGITAL%20FM-SENDER-_L
pls rate my suggestion...
SOURCE: i have a nokia n85 and can't seem to connect it to
Start with the T505 turned off. Make sure the blueooth radio of all devices which were previously paired to the T505 are turned off too. Try to press and hold the power button of the T505 for 3 seconds. It should power up, and start to search for previously paired devices. If it can't find them, it'll enter the pairing mode (its led will be solid lit). Now, make the bluetooth application on your N85 search for new devices. Select the T505 from the list. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers!
Carlos
PS: the T505 should also go to pairing mode if your press and hold both volume keys for 5 seconds.
SOURCE: User Manual for Mororola Motorokr T505 Auto
Sure! You can download your car kit's quick start guide from this location. There is a small insert here too.
Hope they might suit your needs.
Anyway,please, let me know if you need additional informations.
Regards,Carlos
