if it takes a picture then it is a broken lcd screen... if it does not then it is a broken sensor and lcd screen... with the menu not showing that has nothing to do with the sensor just the screen.
2 things could be fault here. If you are able to goto a menu setting and still have pixel issue, then the video interface for the display is damaged. Not usually worth repairing. If the menu shows clear, then try to take a picture, and use a computer to view the picture (USB cable, or remove the memory card). If the picture shows pixels, then the image sensor is bad, and almost never worth repairing unless high end camera and under warranty.
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Your camera seems to have ccd chip problem. Image chips goes bad sometimes and when you play recorded image it is ok but when you want to turn on the camera to take picutures, you'll see scrambled image or no image at all. The remedy for this symptom requires a replacement of ccd chip. The average repair for ccd problem is $100-$130 in the repair market. -James
I have checked to see if I can simulate your problem on my D70.
There are no settings on the Set-up menu to turn off the display.
The display should show for a minimum of 6 seconds after a phot is taken.
You can reduce the screen brightness but that will not turn it completely black.
I presume you have eliminated all other possibilities by changing batteries, card, lens etc..
If so, it would suggest an LCD screen failure which would necessitate a repair by a Nikon agent.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
1 Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
I have a sony cybershot DSC-S650, the LCD was very dark and could not
see anything except if I pointed it at a bright object, everything else
worked ok. I could take pictures but could barely see them in playback
as well.
I took it to Sony authorised repair outlet and was told
the CCD was damaged, they charged me USD $55 to repair it (in Quito,
Ecuador)
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick.
I guess I'm not sure what you need.
No photo shows on screen only blue light
