Electrical Supplies Logo
Anonymous Posted on Jun 20, 2012
Electric switch install
I have 2 electric power sources and have 2 light switches that control different lights how do you install the sigle pole switches
Gene Haynes
Level 3:
  • Electric Master 5,391 Answers
  • Posted on Jun 26, 2012
Gene Haynes
Electric Master
Level 3:
Answers
5391
Questions
0
Helped
2603839
Points
14124
Open following link for single-pole and 3-way installations:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you have two hot wires inside the same box, that is unusual unless the power source is 240volt.
However it is possible that box has two hot wires and each controls a different light.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
Anonymous
  • 550 Answers
  • Posted on Sep 26, 2008
SOURCE: Want to install Fan and light control from one switch.
'define control'
anyway, that all the lights work together makes it simpler
most fanlights, updated by homeowners replace a lamp only unit, with on/off provided at the switch, and cable pulls on the unit to change speed direction of the fan
my favorite is paired dimmer switches, giving control separately of light and fan speed, fan direction still changes on the pull switch, requires 3 wires in the switch box, (power and 2 switched lines), to the lamp connector and fan motor connector, any sparky can pull the extra line with fishtape along the existing cable run. easy peasey.
Really good electricians pull three wire to light circuits, when the house is built or reno-ed. but you know how oftern that is gonna happen, 3 wire costs 3c more per foot, if there is 3 wire in the switch box -your home and hosed
or just for speed/dimmer control a dimmer switch can replace the existing single switch. but you still have to pull the cords to start the fans
its easy, with the caveat that you may kill yourself, or someone else, or burn the house down, if you dont do it right
Anonymous
  • 63 Answers
  • Posted on Apr 05, 2009
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Anonymous
  • Posted on May 05, 2009
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
VtToolMan
Mark
  • 704 Answers
  • Posted on Aug 07, 2009
SOURCE: new Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
A
Anonymous
  • Posted on Dec 03, 2010
SOURCE: I need the wiring diagram
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Testimonial: "This diagram is, truly, helpful. Thank You! "
How do I wire 2 wall lights controlled by 2 one way switches and 2 two way switches either side of a bed?
Try eliminating some ambiguity and describe the operation of one wall light from two switches. Don't describe the switch type just a switch location and how the wall light should behave when a switch changes.
It's difficult to understand how you want a light to operate differently from the typical set of two 3-way switches. It seems you want to control on/off from two locations using 3-ways with the addition of a.single pole to override the 3-ways. Buy that's my interpretation and may not be what you want.
Then double the circuit... so in my interpretation it would take two 3 gang boxes at each side of the bed and two more boxes elsewhere for the lamps.
1helpful
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
I am trying to install a Pass & Seymour Harmony fan speed control switch. It has 2 red wires and 1 black. I hooked up the power to the red line and the black leading to the wiring for the fan. No...
Are you wiring for 3-way or single pole?
In other words, are you using 1 switch (single-pole) or 2 switches (3-way)
http://waterheatertimer.org/pdf/Pass-and-seymour-3-way-3-speed-fan-control.pdf
Before installing device, separate all wires in box and turn power on and then test each wire to bare ground wire >> tester will light up on Hot power source.
Black wire on device is connected to Hot power source.
Red wire on same side of device as black wire is capped off in single pole application.
Red wire on other side of device from black wire goes to the fan motor.
Green wire is ground.
Set fan on highest speed before connecting red wire to fan, and then do not adjust fan speed using pull chain.
I am unsure what volt-amp-testing will show for power output on either red wire, but certainly it will vary as the switch is adjusted to each speed.
Call 800-223-4185 for Legrand tech support.
There is a wallplate with 2 outlets and 2 switches that control 2 separate lights. while trying to install new switches and outlets, wires came loose and now I have no idea what is what.
Open following link to see illustration:
http://waterheatertimer.org/images/Single-pole-switches-in-4-gang.jpg
Each residential electric box has 1 hot wire. This wire should be black.
Hot wire carries power from the breaker box.
Use tester and find hot wire.
Each device in box connects to the black hot wire using short jumper wires.
Outlets: Hot wire connects to brass colored screw.
Single-pole switches: Hot wire connects to either brass-colored screw.
Neutral wires are usually white, and are twisted together.
Neutral wires connect directly to silver screw on each outlet.
Wire going to lights connects to other brass screw on each switch.
1helpful
I need a diagram of a two way switch
Switches are single-pole, 3-way and 4-way.
There are other types of switches also, but none are directly called two-way.
Single-pole is when 1 switch controls lights:
http://waterheatertimer.org/images/Single-pole-switch-300.jpg
3-way is when 2 different switches control same lights.
4-way is when 3 or more switches control same lights.
http://waterheatertimer.org/ST01C-program.html#3-way
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
I have a Leviton single pole rocker switch grnd, pilot light back and side wired #5628-2W i am trying to hook it up so light is on when switch is on i have 2 black wires 2 white wires and 1 ground wire how...
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
How do i wire in a 2 light colour signal to a 2 way switch
Two Way Light Switch Wiring Have you ever wonder how a lamp that is used to light up the stairs of a building is connected to the two switches that controls it from either end? These two way switches have a single pole double throw (SPDT) configuration. Each has a common terminal (COM) with a pole that can be switched between position L1 or L2. The two way light switch wiring can be implemented by using 2 different methods. Both of the methods used are described below.
The first method as shown in the figure above have the COM, L1 and L2 of both the SPDT switches connected together. For incandescent lamp, the recommended wire gauge used is AWG #18. The LIVE AC Source is connected to L1 of SW1 and one side of the load is connected to L2 of SW2. The other side of the load is then connected to NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is at ON position and the other is at OFF position. If both switches are in the same position, the lamp will be OFF.
The other method is as shown in the figure above. In this configuration, the L1 of both SW1 and SW2 are connected together. Similarly, the L2 of both SW1 and SW2 are connected together. The LIVE of the AC Source is connected to COM of SW1 and one side of the load is connected to COM of SW2. The other side of the load is then connected to the NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is ON and the other is also ON. If both switches are in different position, the lamp will be OFF.
Take note that as the installation involves mains power supply, only those who are qualified and have electrical wiring knowledge should do this wiring. When doing the wiring, it is recommended that the power supply is disconnected from the load and the switches.
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Top Electrical Supplies Experts
vince
NOEL
NOEL
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
