After turning the tv on the colors are reddish and slow to conform to the normal color tones. i have a 36" toshiba flat screen tv
My first concern would be that, the picture tube is going bad. The problem you describe, tell me one of the color guns is shorting. In this case I would think the green gun is shorting. There are three color guns in the neck of the picture tube. They are red, green, and blue. Most of the time the green will short as it is powered heavily in most TVs. The next thing to check, is the small board connected to the picture tube. Look for any and all bad grounds on this CRT board. This is another big problem in all Tube type TVs. On this small board there will be three color output transistors, and resistors. These will many times run very hot and will create bad grounds over time. Check and resolder as necessary. If the CRT board does not fix your problem, replace the TV. Picture tubes are very expensive and will not be feasible for replacement. Search for a new TV. Thanks for asking and show all hands of support!
