The console display is blank. The speakers make a slight 'pop' noise when the power is turned on and off but nothing else.
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
http://www.sportsmith.net/images/product_support%5CNordicTrack%5C248194%20-%20NORDICTRACK%20INCLN%20TRAINER%20X7I%20INTERA%20TREADMILL%5CNTL20909.3-299073.pdf
SOURCE: I have a Nordic Track exp1000 i fit and the track is not working.
It's either the electronics console overlay -- this thing often goes on this model -- or your motor is shot.
Have you ever seen it working?
Repairs can expensive.
You can buy an excellent replacement console electronics part for $100 (http://www.treadmilldoctor.com/Nordictrack-Console-Keypad-Overlay) , but if it's actually the motor, then you've still got more to spend.
In home service can easily run $150 for the call plus cost of parts.
If you decide that you're not going to try and get it repaired and you're going to toss it, I'd like to buy some plastic housing parts off that non-working unit from you. Please email me directly.
Cheers,
Mark
[email protected]
SOURCE: Nordic track c2255 console displays FF and will
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
SOURCE: I have a Nordic track summit 5500 and the front
sounds like a bad console. Look for a used one on ebay, but don't buy a new console, you're so much better off buying a new treadmill
SOURCE: nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
you ever find out what the issue was
I have a nordictrack treadmill x71 and I have a white loading bar on the bottom that won't go away
