Log into your router by opening your web browser software, for example Internet Explorer. Type in the address field the ip address of your router. The ip address depends on the manufacturer, but it should look something like this - 192.168.1.1 . A window should appear asking you for your user name and password. If the router is set to default settings, the user name should be ADMIN and the password should be ADMIN. Hit enter. This should bring you to your routers configuration window.
SSID screen.Go to your wireless tab / basic wireless settings. Enter a SSID (wireless network name). The SSID may be on a sticker on the router or you could make one up. Choose a wireless channel. Disable your SSID wireless broadcast. Save or apply changes.
WEP / WPA screen.Go to your wireless tab / wireless security. Choose enable. Choose either WEP or WPA encryption, the latter is a more secure choice. Choose 64 or 128 bit encryption, again the latter is a more secure choice. Enter a passphrase and write it down so you can enter it when it is called for when installing the wireless software on your wireless computer. A hexadecimal WEP/WPA key should be generated. Save or apply changes.cheers
