HP LaserJet P2055d Printer Logo
A
Anonymous Posted on Jun 19, 2012
How to print envelopes on a hp 2055d - HP LaserJet P2055d Printer
3 Related Answers
Anonymous
  • 25 Answers
  • Posted on Aug 14, 2008
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Anonymous
  • Posted on Nov 26, 2009
SOURCE: Can't print envelopes made by
The problem centered around the fact that the HP209 would only print 8.5X11 sheets from Greeting Card Factory. Any other size seized up the pring spool.
We're going to return the HP (We think it's defective) and get an Epson.
BaronVonNuke
Mark Schmit
  • 1915 Answers
  • Posted on Apr 23, 2011
SOURCE: On my new HP laserjet 2055d on large pdf files I
Either make sure that your program is not creating too large a file, or add more memory as that will allow you to process larger files and also make the printer work faster during every day printing.
Testimonial: "Thank you. I think your are right. The printer needs more memory (it has 64mb) and I have ordered more to make the maximum 384mb."
My Riso Duplicator puts a score on window envelope while printing. How to solve the problem?
Don't print window envelopes or try a different make that are made better. They are often problematical. Video from the maker at the bottom.
Printing Envelopes on a RISO Inkjet Printer
Riso UK https://www.riso.co.uk > pdf > Printing-on-Env... PDF We have conducted a series of evaluation tests to determine which envelope types can be recommended for use and the results are shown in the charts shown ...
2 pages
Solved: Melting plastic on envelopes
HP Support Community https://h30434.www3.hp.com > LaserJet-Printing > td-p
When printing envelopes with my M605 HP Printer, it melts the plastic view windows. Any suggestions?
Thread: #10 window envelopes - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Aug 11, 2012 - We have a Minolta 452 and 552. Looking to print #10 window envelopes. I bought heat resistant window envelopes. Put them thru the machine ...
HP laserjet 2055d kept initialising and not printing
-How about try this:
-Go to the printer file. Delete all printing job in the spool.
-Then if any cancel button on the printer. Press couple times to cancel and than now try to print a job see what and how it'll do.
Good Luck
Mai
2answers
Printing envelopes it prints crooked
HP OfficeJet Pro K8600 Printer
Printing envelopes
1helpful
On my new HP laserjet 2055d on large pdf files I get print failure; device error; page too complex. Any suggestions?
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Envelopes won't print
where do i insert envelope to print address?
I hope this helps.
2answers
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
2answers
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
k24674
Grand Canyon Tech
Grand Canyon Tech
