XO Vision X349NT Car Video Player Logo
Posted on Dec 04, 2017
My RCA cables aren't working...
I've hooked up a sound system, and I've taken it to a professional audio installer, and he says that everything is wired right, but he can't find the sub woofer option to turn it on so the RCA cables will work. But I can't find a manual for this radio anywhere to find where to turn it on.
Kicker dx 500.1 keeps ruining my subs
if your sub isnt blown, i'd follow your own idea and look for a bad wiring connections, also what kind of head unit do u have? check the settings on ur head unit to see if there is a seperate setting for your amp/subs if it does have one, make sure it is set properly
if it does not have a setting like above, check the rca cable from the radio to tthe amp, and make sure that the rca cable is plugged in to " input instead of the output
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
1helpful
My hdmi connection for dvd & cable have both stopped working. The receiver is flashing
Unless you've been pulling it in and out, it shouldn't go bad. I assume you've checked to be sure it's properly connected.
HDMI cables should cost less than $20. If you were talked into a $100 cable, you were taken advantage of.
HDMI has a function called HDCP. The TV source and TV have a conversation over it to make sure that only an approved device (your TV) is connected to the cable. This is for copyright protection reasons.
Have you recently connected a new source (cable box, DVD player, whatever)?
Your problem can be in the TV, the cable or the source.
Try substituting for each to determine what's failed.
If you have your TV now hooked-up with component, you may have discovered that there's little or no difference in the picture
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See http://www.svideo.com/scart2.html for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: http://www.retrevo.com/support/Akai-PDP4273M1-TVs-manual/id/741bh140/t/2/ . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
My receiver will only play mono sound...when i hook up just red/white audio cables to my dtv setting. if i plug both in the sound is almost muted. i can hear sound clearly from one side as i plug one or...
Please clarify this statement: "...when i hook up just red/white audio..". Is that for only the one external source or all?
It's not clear if you tried the red and white cable swap at BOTH ends to isolate the signal loss to the source or the receiver.
The TV's audio controls determine how loud and in what format its audio exits on the RCA cables.
WHY do you need audio from the TV in the first place. If its programming originates at a Cable BOX THAT would be the best place to use as the audio source - and digitally to boot.
Digital sources must be assigned in the receiver setup. It's in the manual.
1helpful
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
1helpful
Hi. I've just hooked up my 3500S to a new Samsung
Hi
  • Make sure your SCART cable is fully cabled...for IN and OUT connections..
some SCART plugs works one way..I recommend to replace it with another one at least for testing..
  • Second option,buy an SCART to RCA/S-video adapter and use that one for "s" connection..
here is an example of SCART TO COMPONENT & S-VIDEO adapter on the URL below..
http://cgi.ebay.com/SCART-COMPONENT-AND-S-VIDEO-/140482348595?pt=LH_DefaultDomain_0&hash=item20b5668633
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Top XO Vision Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
