Question about Pelican Video Game Consoles & Games
How do i connect a universal sytem selector - Pelican Video Game Consoles & Games
I have a onn mini stereo sytem but no remote but i have zenith universal remote and i need codes for it
Use code search on your Zenith URC to find something that works. If a search through all codes fails, you may have to try a different uRC. All URCs do not contain all possible codes.
Jul 12, 2018 | Zenith Televison & Video
Universal password for n150
I am not aware there is a "Universal Password" as man made passwords differ.
Feb 17, 2014 | Samsung N150 Notebook
Does this heater need to run on 220
Electrical connections :
The heater is shipped from the factory wired for use with 240VAC, 60 Hz field power supply. To convert the
heater to 120VAC, 60 Hz operation remove the 240VAC voltage selector jumper from the ignition control board
and replace it with the 120VAC jumper. These jumpers are tie-wrapped together and are located on the fuse
board.
Feb 16, 2011 | Hayward 400FDP Universal Series Low Nox...
I have no power to start my motor; wondering if my 7 year old 3 stage Guest power selector switch could have failed. I took it off my boat, looked at the inside, all looks good, I gave it a shot of oil,...
Just connect battery and engine cable on the same post on your battery switch. If it starts now, the switch is dead. If still no start, battery or startermotor dead...
Aug 18, 2017 | Guest 2111a Universal Mount Marine Battery...
Iam getting no voltage tto my fuel pump,front tank doesn't work,I changed the ignition switch,still no luck. the continuos power to my fuel pump reads 6.5 volts. From what I can tell my electrical sytem...
Poor earth connection most likely causing hifgh resistance voltage drop.
Could also be a faulty pump. Run a separate power supply to it and recheck.
Mar 10, 2010 | 1997 Ford F250 SuperCab
My ceiling fans original remote is broken adn I need to get a code to set the universal remote to turn on/off my fan
While it's true a lot of ceiling fan remotes and receivers are universal, there are exceptions. Obviously you need a dedicated ceiling fan remote, not something picked up at a local wal-mart that controls t.v.'s and dvr's. I would need to know what kind of system you have. One of the most common types is a UC7067 4 dipswitch (64 -bit) sytem. Look in the battery compartment of your remote for 4 tiny micro switches this will let you know. If you have this system, you can get replacement parts from www.fanmanlighting.com or call them at 1-866-600-3267
Oct 15, 2009 | Universal Remote Control Hampton Bay...
Have a 2000 chevy blazer, just replaced blower module .still no heat or ac and selector switches don't light up when pressed
my 2000 chevy blazer zr2 4x4 the a/c switch that does 123 and 4,the a/c only works on num 3 setting.ive just replaced the whole a/c sytem and blower relay.it wont work on num 4 at all and when it does it cuts off on its own and then works on setting 3 only?what to do?
Mar 05, 2009 | 2000 Chevrolet Blazer
Manual input selector problem
go to any hardware store & pick up an universal remote that you can program for your dvd.
Jul 11, 2008 | Technics SA-DX930 Receiver
SONY Model Number KV-27FS120
Hi. depending of your t.v .. is it old model.. do you have enough a.v. output . if not .. trying to get a audio and video selector .. with a dvd . aux. vcr, a.v. .... for the remote control .. if your t.v and your dvd is listed on the universal remote .. I dont see why not
Dec 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Cannot locate an input selector to change from cable to a recorder
Try selecting channel 00 enter on remote.....I am assuming
you are missing the original GE remote that has an input button
on it ............? Let me know.........T.
Dec 22, 2007 | GE 31GT659 31" TV
Video Game Consoles & Games Logo
Top Pelican Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
