MY 32 INCH PHILIPS TURNS OFF AFTER BEING ON FOR JUST SEVERAL MINUTES AND WON'T TURN ON AGAIN
Sounds like a power supply problem that typically is caused by a power surge of some sort. Check with tvrepairkit. com for their power supply kit to do the repair yourself.
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
Possible DRY Joints on the power board. Needs either an engineer or someone who knows how to check it.
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
SOURCE: my panasonic 32 lcd tv tc-32lx60 will not turn off
Really sorry abou that. Here's the transcript.
http://www.fixya.com/support/c36637
I have been posting responses all the way through. But you were not able to see them, possibly due to some kind of bug
SOURCE: ghosting and blue tinge on close up on people
It is fixable depending upon the make and model.
once it's off it wont turn on again. I had to wait a day before I starts to work again for the about the same number of minutes. The unit is a year old and half of the year since it was purchased it was off as I use more of 42" Philips TV that I had for more than 5 years.
