SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
SOURCE: dryer runs but will not dry
It may be a thermostat that has gone, thus preventing the heater from going on. Check your power source as well, maybe you have lost a line.
SGt 48
SOURCE: What does display code 1H on GE Profile dryer mean?
It means you have it set for a 1 (one) hour delay start
SOURCE: My GE Electric Dryer model GEQ9858JQ0 will not stay running.
Have you cleaned out the lint filter and the exhaust hose, it's got to be cleaned out to allow air to exit. This will trip the high temp limit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
model dcvh515efoww
modle dcvh515efoww no t codes
