The first time I connected TT520 to laptop everything worked fine.two weeks later it says no driver installed for device and therefor not recognising the device.how can I fix the problem.os on laptop is Vista
What you need to do,
hold the reset button for 20 seconds which is located at the bottem of the tomtom (make sure to use a pin or similar in size).
then connect the tomtom to the computer and turn it on.
this should reconnect and allow you tomtom to communicate with the computer
If you have a memory card in your Tomtom - remove it before you connect as sometimes your PC see your Tomtom as some kind of storage device.
Dave
one of the usb devices attached to this computer has malfunctioned and windows does not recognize it
yes that was the question!!! what is the answer?
suddenly will not connect
usb device not recognized
no drive located
Tom Tom 520, all worked fine but now pc says device in unknown, i searched to resolve the problem and it is said to uninstall Tom Tom then install again from cd, this should work.
I have exactly the same problem
