Question about Razor MX500 Dirt Rocket
I have a Razor MX500 and having trouble holding a full charge. Charger light turns green but after a few seconds bike charge indicator light reads low charge. I had bought new batteries and bike was q
What other parts are there that I can check?
    New Friend:
I have replaced the 2 batteries in E300 , the charger light stays green but it's as soon as I plug charger in to scooter. What is the problem now ?
Posted on Feb 06, 2014
    New Friend:
  • 15 Answers
Remember new batteries take 12 hrs to charge....
Posted on Dec 31, 2012
5 Suggested Answers
SOURCE:
  • 70 Answers
SOURCE: Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Posted on Apr 03, 2010
  • 200 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
Clean and tighten all wires connected to the battery, motor , controller etc.being doubly sure of all grounding wires . Don't take any shortcuts ...remove wires ,clean and inspect for cracking or burning, clean and or replace....this will pay off for you...Good Luck....Tim
Posted on May 12, 2009
  • 427 Answers
SOURCE: off-on switch as bright as when it was new. green
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Posted on Jul 14, 2010
SOURCE: bought a used razor mx500.
Did you ever solve this problem?
Posted on Dec 03, 2010
It will not run it just click
Most likely, the last 2 answers are correct. When you charge the battery, does the light on the charger stay red for several hours before turning green? Check the voltage of the 3 batteries after the charger light turns green. It should be 39-40 volts or so no load. Turn the throttle and see if the voltage drops when the relay clicks. You can connect the batteries directly to the motor and it should go full speed if they are good.
Mar 02, 2015 | Razor MX500 Dirt Rocket
I Replaced the charger port on my Razor Mx500 Dirt Rocket and it ran fine and then just stop. The charger still indicates the batteries are charge but no power. Also I went to check the fuses and manu
Well if it's missing fuses obviously it won't run. When you turn it on does the green light on the throttle come on? if you have a voltmeter that would help. Are you sure the charger is good? if so you want to see 39 volts or so across all 3 batteries. Sometimes the switch contacts develop excessive resistance try shorting them with your screwdriver... if it runs you need a switch. can you hear the controller click when you turn the throttle?
May 21, 2014 | Razor MX500 Dirt Rocket
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
Apr 02, 2010 | Razor MX500 Dirt Rocket
Battery shows a full charge but wheels won't turn while grounded
theres nly 2 things at work here in my opinion, the battery and the charger, if this bike is of any age chances are the battery is no longer good, it may read ok with the meter but when you put it under a oad like trying to ride it it may go to 0000 see if you can mete it under aload
Mar 14, 2009 | Razor MX500 Dirt Rocket
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Razor MX500 Dirt Rocket Logo
1,203 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
