Make sure you are connecting the red and white connectors to Audio IN on the TV.
You really should be using a HDMI wire though...
SOURCE: PS3 hdmi cable
Hold the power button for 5 seconds or more, that will reset to regular viewing ratio. From there you can adjust to whatever you are using. I had the same problem.
SOURCE: No audio or visual via AV Cable
turn the power off in the back and then turn hold the power button in on the front then turn it back on in the back and continue to hold the front power button down for 5 seconds and you should here a beep then let go. Then turn it back off then on
SOURCE: ps3 know picture showing up
If your picture is not showing up try resetting the config settings and if this does not work it could be the GPU overheating.
Try another cable but if no luck it will be this - you can send it in for repair or use a good no display fix to get back to gaming.
