SOURCE: Hi i have a grinder problem with my Saeco Odea Go
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
SOURCE: Saeco Odea Giro highlights the "!" light and wont spurt water.
Try this open the steam knob for about 5 seconds then turn it to the rest(off) position, make sure that it is in the off position.
SOURCE: Saeco Odea Giro - disassembly
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
SOURCE: Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
THanks, but the brew group and everything else in the unit is in good shape, including the grinder motor.
I spoke to a repair technician this morning who advised that they will replace the ceramic disks and burrs and that this is not something I should try myself. I will send it in for repairs.
SAFECO odea go grinder motor spins
