as for the vertical stripes get a professional to take a look at that as for the hdmi you need a hdmi receiver or dvd player and connect to your tv via an hdmi cable to get the hd signal on your tv
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
black or red is usually "hot" (+) . green is ground. power antennae is blue.
speaker wires : stripes on the wire is usually "=". solid color wire is "+"
p.s. the wire with the fuse block is considered the positive side +
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
If a lot of pressure is added to the screen this can cause it to fracture internally. Sounds to me like you need a trip to an Apple repair center if you've already tried rebooting it.
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Good Day, poandflo; After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
along the sides or the center ? if on the sides check the picture format and see if it changes. If its doesn't go away sound like u might have a defective IC on the ribbon cable that plugs into the plasma panel
