To program your remote to your Samsung HD 3500, follow these steps:
Turn on your Samsung HD 3500 and your TV.
Press and hold the "TV" button on your remote until all the mode buttons light up.
Enter the three-digit code for your TV using the number buttons on your remote. You can find the codes in the user manual for your remote or online.
Press the "#" button on your remote. The mode button you selected should blink twice to confirm the code was entered correctly.
Test the remote by pressing the "TV" button and seeing if the TV turns off. If it does not, repeat steps 3-4 with a different code until you find one that works.
If you cannot find a code that works for your TV, you can try the automatic code search method:
Press and release the "Power" button on your remote.
Press the "Up" button on your remote repeatedly until the TV turns off. This may take several presses.
Press the "#" button on your remote to save the code.
Your remote should now be programmed to your Samsung HD 3500.
Here are some general steps you can try to program your remote control:
Determine the brand and model of your remote control. This information should be available in the user manual or on the manufacturer's website.
Turn on your Samsung TV.
Press and hold the "Code Search" button on your remote control until the indicator light turns on.
Press the "TV" button on your remote control.
Enter the code for your Samsung TV. You can find a list of remote control codes in the user manual or on the manufacturer's website. Alternatively, you can try entering codes until you find one that works.
Press the "Power" button on your remote control. If the TV turns off, the code has been programmed successfully. If the TV does not turn off, repeat steps 3-5 with a different code.
If none of the codes work, it is possible that your remote control is not compatible with your Samsung TV. In this case, you may need to purchase a new remote control or contact Samsung customer support for further assistance.
Here is the list with the KNOWN working device codes for Samsung Blu-Ray DVD players. These should work with ANY remote as these remote codes are universal. Samsung Blu-Ray Player Universal Remote Codes (4 and 5 digit)
0199 12051 10812 10702 10060 20199 31868 10766 20573 11903 22069 11060 21075 20240 31295 31500 22329 22369 21470 22489 01877 21044 20820 10650 10814 22556 10178 20490 20045 01982 31304 20744
Below are instructions on How to Program your Samsung Blu-Ray Player to Control your TV.
Use Samsung Blu-Ray Remote Control To Control Your TV
Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...Guide to Programming the ... - Download the Manual - 8 Device Learning Jumbo ...
Ideally I need you to clarify a few details on your exact RCA remote model and number and also whether this is a Samsung TV or other unit like a DVD etc.... that you wish to program
However assuming it is a Samsung TV here is a list of the common RCA codes for this TV. You will need to go through each one individually until you find one that works.
Code 1004 for Samsung TV
Code 1005 for Samsung TV
Code 1006 for Samsung TV
Code 1012 for Samsung TV
Code 1013 for Samsung TV
Code 1015 for Samsung TV
Code 1017 for Samsung TV
Code 1019 for Samsung TV
Code 1082 for Samsung TV
Code 1104 for Samsung TV
Code 1105 for Samsung TV
Code 1106 for Samsung TV
Code 1171 for Samsung TV
Code 1172 for Samsung TV
Hope this helps. If so please do rate my answer.
Otherwise please post up additional details as outlined and I will see what I can find.
