Not certain but sometimes this happens with extreme system fragmentation
try this disk utility and see how it helps
SOURCE: Dell crashes and restarts upon sleep_suspend_hibernate
I'm not a big fan of using hibernate or standby, I've seen it cause too many problems, such as the one you're having. I shut my machine down when I'm done, or let it run if I'm coming back within a reasonable amount of time. I've also seen hibernation or standby create operating system errors or glitches, and premature hard drive failure. If the machine is working properly other than hibernation/standby you should shut the hibernation off and just shut the machine down when not in use. If you're getting this error when using the power button to turn off the computer, then the operating system has glitched or is corrupt and needs to be reistalled. If you need anymore help with this let me know.
SOURCE: hp pavilion dv2000 notebook will not boot up
I had the same problem with a dv2600
"Run online diagnostics to download and install latest PC BIOS and graphic drivers automatically"
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01519032&cc=us&lc=en&dlc=en&product=3646864
Install BIOS update and mine works fine now.
SOURCE: my toshiba a135-s2276 laptop starts up&the shutsdown automaticaly
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
SOURCE: My HP's screen goes black
When your computer reboots, go to the control panel > power options > go to the hibernate tab and turn off hibernation. Then go to the power settings and make sure to change the setting for closing the lid to "do nothing" then change the other settings such as when the computer sleeps if inactive to 30 minutes to an hour. Hibernation is causing the most problems I see with random shutdown etc. One other thing it might be also is overheating of the processor, make sure to get some compressed air and blow out the heatsink vents and grills on the base of the laptop. If these are insuccessful, there maybe the possibility that you have a Malware bug. Go here http://www.filehippo.com/download_malwarebytes_anti_malware/
download and run this and perfrom a quick scan, when it is finished, show results and delete anything it finds.
SOURCE: pavilion dv7 keeps shutting down
Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
