MESSAGE ERROR init EEPROM
SOURCE: Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
SOURCE: epson CX3200 printer error
i just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter www.ssclg.com/epsone.shtml .. my printer works fine again
SOURCE: i want to add my cx3200 epson printer to my pc have lost the cd rom disc
Download these two drivers in order and install, follow prompts to know when to connect printer.
Printer Driver
ftp://ftp.epson.com/drivers/epson10453.exe
Twain Driver
ftp://ftp.epson.com/drivers/epson10573.exe
Hope this helps
Thanks!
SOURCE: Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will
help us determine what cause the red light. To give you heads up as well, the
Printer's LCD screen can help us determine what exactly the offline condition
of the CX3200 is:
Error
message: No color or black ink cartridge-->Press the Color Copy button to
install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the
necessary cartridge(s).
Error
message: Color or black ink out -- >Press the Color Copy button to begin
replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace
the necessary ink cartridge(s).
Error
Message: Ink cartridge error -- > Press the Color Copy button to begin
Solution: There is something wrong with the ink cartridge. Make sure the
cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and
then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and
clear the paper jam by hand if necessary.
Solution:
Paper is jammed. Check for any obstructions under the unit's cover, and in the
paper tray.
Error Message: Paper out -- > Load paper in the sheet
feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button
to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks
securely into place.
Error Message: Scanner error -- > See your documentation and call service if
necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the
transportation lock, if necessary. If it is already unlocked, toggle the lock
back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message:
Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect
it from power, and then reconnect it to power. Press the ON button to turn on
the Stylus CX3200.
SOURCE: Epson CS3200 - Non-specific power-up failure & error message
Did what you said downloaded the Epson Utility...reset my counters......turned the PRINTER OF and then ON while holding down the Red stop button and the Green colour button at the same time...hey presto......printer works good as new...
Its criminal that Epson makes your printer fail based on the number of copies you do even tho there is no fault with the printer in the first case !!
Do you know if there is a Utility for the Epsom sx400 that i have been foced to buy due to my Red Light fault with the CX3200...cant see it on the download..??
