Nintendo Wii Console Logo
Posted on Apr 23, 2017
Wii "An error has occured" when disc is inserted.
My Wii has stopped reading any Wii games. When I insert a Wii game I get "An error has occurred. Press the eject button, remove the game disk, and turn off the power to the console. Please read the Wii operations manual for further instructions". This happens with every Wii game I own (These are all authentic Wii games) but not with any gamecube games. I have unplugged the Wii and left it unplugged overnight as I have read elsewhere. Also my Wii has been making a funny noise when a disk is inserted for a few weeks now. How would I be able to fix this problem myself?
Asavage
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 23, 2017
Asavage
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4233
Points
Maybe the disc is inserted in the wrong direction switch it to the other side that will work.
2 Related Answers
Anonymous
  • 54 Answers
  • Posted on Feb 23, 2011
SOURCE: An error has occurred. Press
Hi there mortil
What to do when your Wii Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Nintendo if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Wii to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a Wii Repair Guide that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
Chris Foley
Feel Free to leave me a comment if you need further assistance.
A
Anonymous
  • Posted on Mar 04, 2011
SOURCE: when the game disc starts
I cannot say what the issue is, all I can tell you is to call Nintendos technical support and if its still under warranty have them replace it.
Heres a user manual: http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Console makes clicking noise when disc is inserted and disc will not start? Screen says error has occurred and to consult manual. It happens with every disc I insert
I Had the same thing happen! It has to do with the retention clip. Here you go:
How to Fix Wii Disk Read Errors Game Front
After you fix it, don't leave game disks overnight or in for extended periods of time as that pulls the clip down.
My wii won't work when i insert a disc
it may be your wii. first, check on another game. then, if it's still not working, then you havve to send t out too get fixed or buy a new wii.
Wii Disk Error
Unable to Read the Disc" Error, or Disc Not Recognized (Will Not Play Game Discs) Situation:
  • The Wii console will not play game discs (disc is not recognized)
  • System displays either error message "Unable to read disc" or "Disc could not be read"
Important!
  • If this problem happens very infrequently, it is normal and does not indicate a problem. A Wii Lens Cleaning Kit can be purchased to help keep the lens clean and prevent the situation from worsening over time.
  • Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
  • The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
  • An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • Verify that the console is placed correctly.
    • If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
    • If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
  • Verify that the disc is being inserted properly.
    • If the console is placed horizontally, the disc label will face upwards.
    • If the console is placed vertically, the disc label will face to the right.
  • Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
    • If the disc is dirty, try cleaning the game disc. (How to)
    • If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
  • Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Situation Not Resolved:
How many games does this occur with?
The wii won't read the disc
Situation:
What to do:
  • This message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • If the Wii console is laying flat, verify that the system is not placed upside-down. The game disc slot should be above all three buttons and the SD Card slot.
    • If the console is placed vertically, the disc label will face to the right. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically (learn more)
  • If only one Game Disc displays this error message, it will need to be replaced. Click here for Game Disc replacement options
  • If the error is occurring with most or all Game Discs or all of one type of game, then this indicates a problem with the system. The console and one or two example discs will need to be sent in for repair. Click here to begin the repair process.
function rvl_ts_sys_unable_read_disc_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_unable_read_disc",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_unable_read_disc_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_unable_read_disc_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_unable_read_disc_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } function rvl_ts_sys_unable_read_disc_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_unable_read_disc=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_unable_read_disc_techDif(){ //it broke document.getElementById("rvl_ts_sys_unable_read_disc_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_unable_read_disc_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_unable_read_disc_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_unable_read_disc_psurvr; req.send(null) } Was this information helpful? yes.png no.png
My WII will not read any disk and we do not have a menu. All it will say is unable to read disk.
Unable to Read the Disc / Disc Could Not Be Read Situation:
What to do:
8helpful
When inserting game disc it says "disc cannot be read. Refer to the wii operations manual."
  1. Refer to the Wii operations manual.
  2. Try cleaning the disc with a lint-free cloth. Wipe the disc in strait lines, not in a circle.
  3. Don't move the Wii around while there is a disc in it. Do this to prevent further damage.
  4. Try a different disc, preferably one that is much cleaner. If it doesn't work, there is an internal error with the Wii.
5helpful
2answers
Nintendo wii message reads: error occured remove disc turn off console check operations manual for information! on 2 new games
Some older Wii units also have trouble with Dual Layer Discs, which pack more info onto a disk like Super Smash Bros. Brawl and Metroid Prime. If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. the other resolution for this is to change the laser on the system but it will cost you for that. Try to clean the lens first it might read the new disk.
Thanks for using Fixya.
Error message when disc inserted into Wii
it migth be upside down game broke or it is a burned disk and it can not be used anymore can u help me with my wii promlem too here is my problems link
To install wii fit
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
    If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
