I asked a question and got a really quick answer...thanks so much...however, the answer said that i should change the fuse for the control panel....
where is this? how do i find it?
there don't appear to be any fuses that i can see and i don't see anything listed in the manual.
thanks again,
sw
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
F0
Electronic oven control failure
Replace electronic oven control (also called EOC or clock).
F1
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
F4
Shorted oven temperature sensor (RTD)
F5
F6
F8
Oven door lock failure
Check lock relay and door switches.
SOURCE: Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
