The motor comes on but the blades won't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
To add onto my answer.... you're better off buying a new base, the above works but not for long in my experience. My maintenance lasted a short time before it seized again. I picked up a base off of E-bay for $15. Count your fins on the bottom of your base, if you search "Ninja Extractor Base" it should turn up a bunch of choices.
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
SOURCE: Blade won't turn in Cuisinart Duo Blender -- not motor
You have to unscrew and disassemble the blades - pretty easy, just take two rags and grab the blades with one (so you don't cut yourself), and then turn the rubber piece on the other side COUNTER CLOCKWISE, opposite of what you would do to loosen. the rod that runs in the middle that's connected to the blades on mine was all corroded, so I sprayed it down with WD-40, took my Dremel to it and smoothed out the corrosion, added some fresh grease ($2 tube goes a long way), washed the other parts with some Dawn and dried completely, reassembled and it runs much better! Not sure how long it will last, but I have a feeling that one time I ran the blender for a long time instead of pulsing, and the grease that came with it couldn't handle the heat from it turning so long. Anyway good luck!
SOURCE: Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
SOURCE: I have a bamix M200 hand blender & the shaft d...
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
SOURCE: How do I fix or
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Its the base. Same thing happened with mine. I bought a new unit at Costco and tested my old pitcher, blade with new base and worked like new.
