Question about Casio Office Equipment & Supplies
How do i add percentage on CASIO MS-8S.
If I try to add 10% to 100, the answer i get 111.1111111111 - My input 100+10%, i am expecting 110, calculator gives me 111.1111111111
  • Myles Thomas
    Myles Thomas Apr 24, 2019
    A fixed support program is launched for the future times. The citizens of the time andhttps://www.analyzedu.com/writing-servic... are marked for the individuals. The changes done for the production the terms for the humans.
  • Angie Smiles
    Angie Smiles May 13, 2019
    Thank you Pablo so much for your lovely words and it is wonderful that you are following your passion
Whats the point of the % button then?
Posted on Feb 09, 2015
SOURCE:
Batstar
  • 122 Answers
SOURCE: Casio seem to have a problem with the percentage key
The issue is the fact that you are adding the %. You need to Multiply it by 1.1 instead of trying to add 10%. This is a wonky equation anyway, because your not specifying what you want to add 10% of. This is why you are getting a weird answer.
Posted on Jun 20, 2009
SOURCE: Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Posted on Jan 11, 2008
SOURCE: calculating percentages
how can i change or fix an exchange rate in Xasio JF - 100TE calculator
Posted on Jul 10, 2008
SOURCE: my calculator will not let me add or subtract percentages.
It would appear most Casio’s have a similar problem I believe this could be a fault in their programming and am awaiting reply from Casio and some of its distribution outlets.
  • 8081 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
When I try to make 100 + 10% answer is 111.11111... and not 110, How do i correct it?
best way to calculate percentages quickly is to multiply base number (100) by 1.xx (where xx is the percentage desired - here it would be 10 or just 1)
100*1.1=110
Works on every calculator every time.
Mar 03, 2015 | Casio MS-10VC 10-Digit Display Calculator,...
Minus 20% of 175.00 using the percentage key
On most Casio calculators you must type: '175 x 20 % -' (and '+' is for adding a percentage)
Feb 18, 2015 | Casio MS-80S Calculator
Casio ms-10vc, when I try to make "100 + 10%" answer is 111.11111.... Is not correct, how I can fix this?
Of course it won't give you the right answer, type 100x10% then add the product to 100.
Aug 01, 2014 | Casio MS-10VC Calculator
How to interpolate with 991MS
i am giving the key input with an example..
example-
at 0, value is 300
at 50, value is 270
so how much at 30...
On 991MS,
Go in Reg mode, for doing that : press Menu,Menu, 2
Enter the values as follows,
0,300 and press M+ key on the calci
(Note: there is a "," in between 0 and 300)
then enter the following,
50,270 and press M+ key
now enter the following input exactly as displayed below:
(30) shift 2 > > > 2 =
you will get the answer as 282.
I hope you got it!!!
LOFT!!!
Feb 22, 2011 | Casio FX-115ES Scientific Calculator
Jun 20, 2009 | Casio MS-80TV Scientific Calculator
My calculator will not let me add or subtract percentages.
I have a Casino MS-80S and yea, the percentage works different. As example to take 100 and subtract 10%, this is what I do: 100 X 10% - and then I get the answer 90 after I press the minus key. To add the percentage instead, 100 X 10% + will give me an answer of 110, after I press the plus key.
Apr 04, 2009 | Casio HR8TM Calculator
How to use %
From the manual:
Function: Keys
Answer
Percentage: 100 x 5% 100 x 5 % 5
Add On: 100 + (100 x 5%) 100 x 5 % + 105
Discount:10 - (10 x 20%) 10 x 20 % - 8
Ratio: 30 = 60 x ?% 30 (division key) 60 % 50
% change: 12 = 10 + (10 x ?%) 12 - 10 % 20
Mark-up: 25% mark-up of 120 120 = 25% 160
- 40 (profit)
Mar 03, 2009 | Casio MS-80TV Scientific Calculator
Percentage Key
I've been searching for the solution to this problem, as well. Apperently, there's no user's manual for this calculator. I'm going to call Casio on Monday to see if they can send me some sort of instructions. (800)962-2746 or (609)395-0154
good luck!!
Oct 25, 2007 | Casio MS-80TE Calculator
Percentage button!!
they call it hardware malfunction. try removing all batteries in it and wait for 30 seconds before reinserting the batteries. If the same problem still exist, the unit is permanently damaged.
Aug 23, 2007 | Casio MS-80TV Scientific Calculator
1,085 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
