I have a 2006 toyota innova diesel, the fuel warning light is on in the pannel guage that indicates water in the fuel filter. i already replace the fuel filter but the warning light is still on
the fuel system light could be low fuel level, vent problem or water in the fuel from condensation in the tank
take it in for a service check and code reading
www.fortuner4x4fans.co.za/...fortuner/.../382-replacing-the-diesel-filter/ May 15, 2013 - 12 posts - ‎8 authors
Car: Fortuner 3.0 D4D 4X4 2010 ... It would also be great to have the knowledge if you need to replace it in the bundu. ... Unplug the top connector on the fuel filter ... Toyotacharged me over R400 labour to do a 5 min job! .... doesnt create an air lock or vacuum of some sort- its free but you have to ask for it.
Low fuel warning light - Fuel
May 31, 2014 ABS problems - Electrics
Feb 26, 2014 Low Fuel light on permanently - Electrics
Sep 26, 2013 D4D Fuel FIlter issues. - Others
Jan 1, 2013 More results from www.fortuner4x4fans.co.za
Another cause of power loss in diesel engines is clogged fuel filter. Some vehicles have additional fuel filter INSIDE the fuel tank. I had my tank taken down and the inside filter cleaned and it fixed the problem. Some petrol stations and repair shops provide this service. If replacing the fuel filter in the engine compartment doesn't fix the problem, try this one. See FB "Toyota Innova Owners Phils" for more pictures.
The indicator you see is call a water in fuel warning lamp.
This a very important warning and you will need to take corrective action ASAP.
As a diesel owner,you need to know diesel fuel can attract moisture. When condensation (water droplets) collect inside the fuel tank,it will contaminate the diesel.
The corrective action is to locate the drain **** on the fuel filter and CAREFULLY drain the water from the bottom of the filter housing. (with engine off / key out)
The water in fuel warning light will go off as soon as the water is drained.
Use one bottle of RED Iso-Heet to remove any additional water inside the fuel tank.
Yes, this is indictating at least 1 low tire of the 5, maybe more...Check ALL 5 tire pressures and set them to 29lbs, as per the specs and then turn your key to"ON"...then push and hold the button under the steering collumn until the light on the dash flashes 3 times, indicating that you have re-set the computer to recognize the pressure that you now have set....
Full instrumentation pack (four
ancillary guages plus tachometer) - with volt meter & oil
pressure
guage.
Speedometer, odometer,
tripmeter, fuel
guage & water temperature guage standard in addition to
the above.
WARNING LIGHTS: High beam, rear
window demist on, turn
signal / hazard light, alternator fail, lights on, park-brake
on,
washer fluid low, radiator coolant low, cruise control
indicator and
low oil pressure.
AUDIBLE WARNING CHIMES: low
fuel, lights
on, low alternator charge, low oil pressure, high coolant
temperature
and brake failure.
Trip Computer standard
featuring fuel
consumption figures, distance to empty, average speed &
time
display.
I found this site, no mention of the fan in a cylinder, but I'll let you figure it out. Hope this helps. http://www.trueblueford.com/ed_pages/EDfalcon_fairmont.html
