For some reason, our shark steam mop stop working. Usually after I plug the steam mop, the power light would light up then you would hear & see steam coming out of the mop's head but all of a sudden no power light would go on and no steam would come out. I can still use the mop, cause water from the tank still is able to flow down to the head. It's just that I'd have to use it like an ordinary mop not as the steam mop I liked. Pls help!!!
HEATING ELEMENTS BURNT OUT. WILL COST OVER $100. TOFIX. SHARK NOW HAS A NEW MODEL "SHARK 3" MUCH BETTER
Don't panic, the heating element is likely OK, however there are two inline fuses to it and one of them is not working anymore. If you are confident in disassembling the unit, it can be easily traced with a voltage meter. However if that is something you are not comfortable with I would suggest getting a professional estimate vs. replacement.
SOURCE: I loved my Shark Steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
SOURCE: my gold shark pro mop (costco) steams inside the
Hi escada48036,
Sorry to hear about the problems your having with your Shark. One of our experts, heatman101 wrote a tip we have in our files. Here is the webpage for the tip: http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
Copy and paste this into your browser and the page will open up for you.
In the tip he describes pulling off the attachment and finding a small hole that comes out of the tank and leads to the hose. From your description, this sounds like what is plugged up. I think once you clear that, steam should flow through fine.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
