SOURCE: HTC hero won't let me save my picture mail on my m...
Go to the adroid market and download something like astro file (free)
SOURCE: have the htc hero 200.
No,there is now way you can turn the phone without power button.
This is hardware related.
If you take a look at the inside of the power button, there are 2 points making contact when you press the button.
If you press it, the software will recognize this and the screen will turn off.
If you press it long enough you'll get the "Do you want to turn off your device" message.
But, if water gets underneath the button, the 2 points may be making contact, because water/alcohol conducts.
if the button is very weak. Due to this, it may not properly work if you have used it for a long time.
Just open the HTC hero and clean the contacts and try again.If not working water may be poured on it.Check for the water marks on the boards.Then you have to replace the board or solder or re-hot it accordingly.
If you don't have hand on in it.Please take it to nearest service centre.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
SOURCE: I need to recover deleted
there is no way to do it from the phone but the court can get it from the cellular provider via court order. there is an app you can get for free in the market place called back up sms the app is by michele valantini it saves all your texts to your memory card and its free!!! i hope this helps!!!
SOURCE: please help unlock htc hero gsm from telus
Free unlock codes are risky. I don't recommended it
because it can damage your phone.
First you will need to purchase an unlock code. As you get your unique unlock code, usually they'll send you the unlocking instructions as well, so you'll be able to simple unlock it yourself!
http://unlockphonenetwork.com/products-page/htc-unlock-codes/htc-hero-unlock-code?cid=25
You can easily unlock HTC Touch Pro2. Just insert Invalid Sim card. it will ask you for unlock code. Enter unlock code. Your Locked Touch Pro will be Unlocked and able to accept any GSM Sim card.
You should buy an unlock code from a trusted HTC unlocking service.
Check the recommended link.
