I attached antenna with its coax cable to the Ant In jack. I do not know how to use remote to oick up antenna. I do not have manual
SOURCE: 3 of five local channels went to snow
are there any lightnings or thunder in your area when it happened.try checking your tuning settings,maybe the program was reset so u need to reprogram the channels again.try removing the batteries of your remote and put it back on again then try to access.i have encountered that problem and i end up buying a new
tuner module.and that fixed the problem.
I have a Phillips. If you have a menu remote press tv. I panicked when that happened to me. I have RR and if you press the yellow A
and ctr at the top left for about 30 seconds should reset remote.
SOURCE: I have installed a Digitalstream DTX9950 converter
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
SOURCE: My tv will not recognize
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and procede to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat toclick the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keyppad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develope dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a smal bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons . Once you have completed test with your camera you can use the remote.
That's it, I hope you got it going again
SOURCE: My tv will not recognize my remote. It stopped
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons . Once you have completed test with your camera you can use the remote. That's it, I hope u got it going again.
