I have a Dish Network VIP722 and a Vizio VHT510 sound bar. When I change channels, sometimes the sound bar looses sound completely. I think it's because of the delay of the VIP722 of sending the sound to the sound bar but I can't be sure. The audio is connected from the VIP722 via HDMI to my Vizio VF551XVT TV then from the TV to the VHT510 via optical.
SOURCE: DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
SOURCE: DISH Network DVR-625 - Audio Problem
FIRST TRY CONNECTING THE RECEIVER TO THE TV VIA A DIFFERENT MEDIUM SUCH AS RCA INPUTS IF CURRENTLY CONNECTED WITH COAX.
If the problem is still evident you can send the TV1signal to TV2 or vice versa. This is accomplished by switching the output cables from tv 1 to tv 2 and changing the tv you want to use as your "monitor" to the proper channel. If viewing tv1 on tv2 change the TV channel from 60 air or 73 cable to 3. if using tv1 to view tv2 the process is the oppposite from 3 to 60air or 73cable.
To check which channel tv2 is modulated to do the following:
go to TV2 and with it on press menu, 6, 1, and then 5 on the Dish remote. That will dispay both tv output channels. You only need to be concerned with TV2.
This should isolate the problem by either it being present on both TV's using the TV1 output, which would mean the internals of the receiver are faulty, or if it is fine on the other TV it would indicate that the problem lies with the TV itself which is unlikely.This is assuming the FIRST method did noyt resolve the problem.
You may also want to try running the medium source from the back of the receiver directly to the TV.
This is all assuming you receive your locals through the satellite and not an off air antenna. Hope this helps you out.
SOURCE: connection to TV by HDMI cable
The 625 is not a high definition receiver and therefore does not support hdmi. You can use RGB or S-video to provide a higher quality picture than the coax output. If you need more options let me know. Thanks for using Fix Ya.
SOURCE: I lose my audio often for non-hd channels with dish 622 dvr
The problem could lie in youir HDMI cable, this is a common issue. if you swap HDMI cables and still have the same problem then bypass your A/v rec and connect your 622 direct to your tv and see if the problem persists, it it does, then your DVR needs to be replaced, you can call dish for addition troubleshooting if it is in fact your DVR.
SOURCE: We have Dish Network VIP722 on only one HD tv at
This is a problem that many have. If you are recording on TV1, and the receiver is in dual mode, then you are only able to watch what you record. But you can set your recording to TV1, and then put the receiver into single mode, and switch from the recording to live TV.
Becki Barned
DISH Network Customer Service
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
