Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator Logo
Posted on Nov 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool oven designerstyle
Hi; I hope you may help telling where the problem Might Be with my Over, Wirlpool Model Named "DesignerStyle" Only the top Burners and the Neon are working, In the Oven the Light and Burners don't work at all, also the Timer/ Clock is not showing anything. The Breaker and the Fuses have been changed. Any Idea ?
Chris Huff
Level 3:
Top Expert:
  • Whirlpool Master 6,289 Answers
  • Posted on Nov 10, 2017
Chris Huff
Whirlpool Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019978
Points
74913
Most likely the control / clock has gone bad or possibly a burnt or loose wire connection
3 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on May 21, 2008
SOURCE: Whirlpool gold self cleaning oven
is it screwed all the way in??Using a meter test the bulb socket for power.If its showing no power check the light switch
Anonymous
  • 1606 Answers
  • Posted on Sep 06, 2009
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Anonymous
  • 1998 Answers
  • Posted on Apr 30, 2011
SOURCE: WHIRLPOOL MODEL.GS6SHEXNS00. Light doesn't work.
this is due to a short in the wiring most likely in the bulb socket you will have to take the entire light assembly down and trace back on each wire somewhere it is either pinched and hitting metal or there is a split in one of those wires that go to the light itself if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks again I await your reply Rick
p.s time to get out the ol multimeter and start doing some tests also check the end connector that plugs into the socket itself it is possible to still get voltage and have a split wire that is hitting off the inside of the cabinet in the ceiling area of the unit I await your reply Thanks again Rick
Is there a reset button or fuse in a wirlpool umc5200bas microwave?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
24helpful
3answers
Is kenmore made by whirlpool
Hello, the simple answer is yes, most Kenmore appliances are made my wirlpool and then the Kenmore logo is attached. Hope this helps. Mike
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 • Ovens
I have a wirlpool oven thats thirty years old model rde1330081
yes the elements are changeable .if you look in the rear of the oven where the elements go through the liner you will see screws Turn the power off to the oven after doing so remove the screws on the elements.GENTLY pull the element towards you you will see wires on the end of the element remove them and replace with new element.(SOMETIMES YOU WILL HAVE TO REMOVE BACK PANEL TO GET TO THESE WIRE JUST MAKE SURE POWER IS OFF TO OVEN BEFORE DOING ANY REPAIRS
How to get oven door on wirlpool electric range
Try this;
In yout browser bar type in uk.youtube.com
In the search box type in Fitting oven door hinge
Then click on appropate video.
You may find this helps.
Please leave comment to let me know if you found this helpful.
Thanks.
2helpful
2answers
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
I have a Whirlpool Fridge, model #GDSHAXNB00. The ice maker is not currently working. It appears that the ejector arm piece that fits into the outside wheel that turns it has broken off. Therefore, when...
If this is not the part Here , then navgate through the site to find it.
Parts can be ordered locally, online or through Whirlpool distributers.
THe Wirlpool website is quite hepfull, but you need to input all the infformation first.
2answers
Whirlpool Range RF367 Error Code F1E1 appears when attempting to turn on oven.
Hi Rooster,
This it the proper solution for your problem:
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
I would need the complete model number to give you a price and part number for the ERC. Just let me know if I can help you more.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Refrigerator light whirlpool designerstyle
well there is no magic button to push or anything like that some times they get stuck in those plastic holders get a pair of work golves or heavy towel and unplug the unit then just twist it out if the bulb seperates from the base get a pair of needle nose plires and grab it by the base and twist it out
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
