Well i plugged in my t.v and it turn on normally and after i moved it and plugged everything in i turn on the t.v and i had no picture. after that i turn on and off the t.v and after that didn't work i unplugged it and after a few mins i turned it back on and got picture for about 2 seconds and it i lost the picture but after a few more seconds the picture came back but than the picture went away again how do i fix it?
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.
SOURCE: disconnecting vcr in a combo
No can,t do that tv will not work at all if do so.can you put a tape in the tv some time the tv will stay on . if so you have a drity mode switch under the vcr deck. itry to clean.
SOURCE: screen turns black after a few seconds
Check the software and if is is not BX23U-1.5.0.0_03531 upgrade it by downloading the software from www.p4c.philips.com onto a USB stick. If that don't fix the issue change the small signalbaord.
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
SOURCE: Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
