2001 BMW 325 Logo
donnie brown Posted on Aug 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The blower motor quit working after a month of not wanting to shut off
The blower motor on the heat and ac was wanting to run all the time even when the car was shut off . i was un hooking the battery so it wouldnt run it down over night . then one day i was going down the road and it smelled like somthing was burning and the blower motor wouldnt shut off so i pulled the fuse to shut it off . After puting the fuse back in it no longer works at all
Rick M
Level 3:
  • BMW Master 4,148 Answers
  • Posted on Aug 30, 2017
Rick M
BMW Master
Level 3:
Answers
4148
Questions
0
Helped
1254244
Points
13941
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on Jan 16, 2009
SOURCE: 2001 BMW 330i..Fan for AC/vent not working?
it's either a fuse or it's a bad blower motor, it could be a bad blower motor resistor but usually you'll get either high or low only, so if you have nothing on any speed, high low etc, and all the fuses are ok chances are it's your blower motor.
kdm56
  • 48 Answers
  • Posted on Apr 30, 2009
SOURCE: Battery on BMW 740i keeps dieing
you need to disconnect one side of the battery, put one lead from an ampmeter on the battery post you have disconnected and the other ampmeter lead on the cable you took off the battery. with nothing turned on on the car , all doors closed the reading on the ampmeter should be no higher than 0.17 amp, if it reads a lot hgher go to the fusebox and remove one by one all the permanent supply fuses looking at the reading every time until you find the circuit that is causing the high reading, this will be the drain. alot of the time it can be central locking system playing up, boot light, glove box light not switching off, stereo wired wrong. hope this helps.
Anonymous
  • Posted on Jun 01, 2009
SOURCE: Engine running hot
change the thermostat it is stuck in closed position
Anonymous
  • 61 Answers
  • Posted on Jul 22, 2009
SOURCE: Heater/AC fan motor keeps running after car is shut off
that's normal when hot, but should't run down the battery. if severly overheats ffnd/fix that problem. the other will probably dissapear . if not excessively hot then the fan heat sensor is faulty....
Anonymous
  • 308 Answers
  • Posted on Aug 04, 2009
SOURCE: 1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
2003 Honda Accord v6 AC and car alarm electrical issues, maybe connected ?
what sub model accord, v6 LX ,
manual or full climate control option??? guess full.
fuses not checked PCM scanned for DTC errors EVAC, hopeless/?
so car starts and runs sand drives ok, <<< not told that.
yes the AC brain on most modern cars is BCM brain controls
and the brain does control the AC compressor. if that is dead so be AC, THE COMPRESSOR CLUTCH, is run by PCM RELAY.
NOT TOLD OUTSIDE TEMPERATURE NOR COUNTRY../
HERE IS A LIST.
1: CHECK ALL FUSES FIRST, CAB AND ENGINE BAY ALL FUSE BOXES SKIP NONE.
2: CHECK IP CLUSTER FOR ERRORS ,ALARMS ERRORS OR LAMPS GLOWING OR IMMO LAMP SHOWS IMMO IS UNHAPPY, MODE.
3: ENGINE STARTS AND RUNS AND CAR DRIVES.?????????
4: HEAD LAMPS WORK KEY ON AND OFF. ,
5: OTHER ELECTRIC FAILURES OR JUST THE BLOWER ONLY?
6: SCAN THE pcM FOR ERRORS, AC IS CUT DEAD EVEN FOR ENGINE OVERHEATING OR OVERLOADED !!! OR IN LIMP MODE/
yah can't fix modern cars lacking a scan tool, no way./
bLOWER FACTS
PER THE SM BOOK REAL
THERE IS A BLOWER RELAY AND SOME FUSES. 12VDC SIDE.
FUSE 30 DASH
AND 21 HOOD, BOTH MUST BE GOOD. and fuse 12 V6
THE bLOWER gets GROUND FROM THIS
Audio-HVAC--Display Panel
l AND ITS BLOW POWER TRANSISTOR MODULE
SO WE KNOW THE TRANSISTOR IS off. IS CAUSE 1.
ONLY WHY REMAINS!!!!
YES THE CONTROLLER DOES NOT WANT TO RUN ANY DEAD BLOWER AND RISK ICE DAMAGE TO THE EVAP CORE.
THE Audio-HVAC Display Panel, READS MOTOR SPEED ACTUAL. speed (a kind blower tachometer wire)
IF SAY A INSECTS NEST JAMMED UP THE BLOWER FAN
THE AUDIO -HVAC, MODULE SEE THAT AND CUTS AC DEAD BY DESIGN AND HARD GOOD REASons/
the THE Audio-HVAC , has the ICE up sensor and monitors R134a
high/low switch and if wrong, tells the PCM to shut down its
Clutch solenoid to compressor ending all AC .
I am no sure what blower does.
but I can say this tell of blower works in heat mode or blower + no AC no HEAT mode. yes then the blower is not bad, nor the controller
what is wring is inputs to the controller are dead wrong
and not scanning the PCM after fuses is why you don't know.
l;earn now this works
Audio-HVAC
Display
Module
https://eautorepair.net/Marketing/Default.asp
not checking fuses first then scanning the PCm is why answers simple are not found.
like these and scads more.
Trouble Code: HVAC 12 (3.0L V6 VIN - Std)
A Problem in the Blower Motor Circuit
Trouble Code: HVAC 13 (3.0L V6 VIN - Std)
HVAC Control Unit Internal Error
Trouble Code: HVAC 14 (3.0L V6 VIN - Std)
An Open in the Evaporator Temperature Sensor Circuit (ICE Up preventions)
Trouble Code: HVAC 15 (3.0L V6 VIN - Std)
A Short in the Evaporator Temperature Sensor Circuit(ICE UP)
3helpful
3answers
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
MY AC COMPRESSOR IS RUNNING BUT THE AIR WOULDNT COME THREW SOMETIMES IT BLOWS SOMETIMES IT WONT IS IT MY SWITCH BOARD UNDER MY RADIO IS BAD
The MOST LIKELY cause of your problem is a bad blower motor. The next time it quits, look up under the right side of your dash and "thump" on the motor housing with your hand, if it starts blowing again when you do this, replace the blower motor.
NOTE: It would be easiest to go ahead and remove the lower trim panel from under the dash (even if the blower is working at the time) so access to the blower motor housing will be easy when it quits again.
1996 Ford Thunderbird LX - AC/Heating A few months back I had my AC recharged (At the time my heating still worked) and it worked fine for awhile, but about a month after that I would turn the defrost...
I'm afraid you have the deluxe system,my friend. It has 2 electronic circuit boards that may be going bad. Very expensive unless you can find used or aftermarket.
I hope it's just the blower motor, but I had the other thing happen and I had to wire around it,losing my AUTO temp and blower control. don-ohio
2004 focus 80,000 miles/6 weeks ago, using ac with blower on high, blower gradually shut off and car produced bad smell. Drove home with ac off, blower off, had car checked and nothing found. Now it's...
The 'whirring' sound from the blower motor could be a dry bearing or damaged armature (part of blower motor that the brushes ride on), or just wore brushes. The smell could be the motor winding wires burning due to blower motor bogging down and overheating. You can replace blower motor with new or salvaged one.
The heat will not work at all as well as the a/c it just quit
CHECK AC / HEATER IGNITION FUSE IT WILL BE 10 AMP FUSE.CHECK HVAC BLOWER 20 AMP FUSE.HAVE BLOWER MOTOR HOTWIRE TO SEE IF BLOWER MOTOR WORKS.BECAUSE THE AC / HEAT CONTROL MODULE OR SWITCH COULD GO BAD WHERE NOTHING WORKS.
1helpful
3answers
'94 Cadillac DeVille Concourse. My winsdhield
Follow the wires from the blower motor back to the blower motor resistor, normally only a few inches away and held in by a 7 mm screw. Replace it
My Buick 2000 is having electrical issues. The heater blower will work sometimes on high and other times when shut off can't get it running again. Now sometimes everything decides to work heater blower low...
Hi Adam,sounds like your blower motor resistor is bad,it controls your blower motor speed.Here's a link on how to replace,read the beginning and it will explain how the system works,as it says,their a different types for your vehicle so remove and take to Autozone and match it up with a new one. Repair Guides Heating And Air Conditioning Blower Motor AutoZone com Here's a link to some new one's. Blower Motor Resistor
1helpful
2answers
AC Blower motor died
This is more than likely just the resistor as a bad motor wouldn't start at all,And low refrigerant(Freon) has nothing to do with the blower.
15helpful
5answers
1995 buick park ave blower motor stays on
Replace your blower motor relay. It's located under the hood on the firewall passenger side.93ecbeb.jpg
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
