My camera was fine the other day i did nothing to it where it would have broke down but now when i turn it on the screen is white you can still take pictures and they show up fine on the computer but you can't see anything on the screen
SOURCE: Olympus 720 sw LCD Screen blank & white
Just in Time for Christmas then!
So decisions - live with out the screen- it appears to be a connexion failure or a main board failure.
Or replace the camera - a repair will cost almost as much.
SOURCE: Hi, how do you take black and white pictures on
you can't shoot in black and white but you can take a picture and change it to black and white.after taking your picture use the color edit option at playback.arrow right or left to choose the picture then press the ok button.use the right and left arows again to select desired color and press the ok button again.this will save a seperate image copy of you original only in black and white.
hope this helps.
SOURCE: I just purchased an Olympus
Olympus Stylus Tough 3000 prints date on image if you connect it directly with printer to get print out of pictures. Printer must have PictBridge mark to receive picture data directly from camera. Usually this type of printer calls photo printer.
Olympus Stylus Tough 3000 does not show time/ date stamp in picture files either in camera playback or transferred in computer. It only prints date info while printing photos through photo printer.
Connect camera with printer and select Custom Print in setup/ print mode, you will see Date option (with/without) to get photo printout with desired info.
Above info also available in user manual, check page-54 fro more details. Click HERE to download related user manual free copy.
Hope these info will help you.
Thanks.
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Here is a tip that I wrote
about how to find the manuals, drivers, downloads and support
for Digital Cameras.
Digital
Camera Manuals, Drivers, Downloads, and Support
heatman101
