Unlock codes
You can get the Unlock code from the site Onlinegsmunlock.com/supported-phones/rs7wp7/ and Unlock it...
SOURCE: how to unlock Htc Touch Diamond !!
over at xda forum the scumbags are charging people for the unlock software i got free from a german friend. this definatly unlocks htc touch, diamond, pro exc its really tricky to excute the last stepsbut it definatly works. all you need to do is join this site free and search for diamond_unlocker or browse through our ppc setion you will find it as i said its free of charge to join and download instructions are very easy to follow after you have completed steps 1-3 you need to flash a new radio. http://www.extremplanet.co.cc/forum/
SOURCE: Request Help: Unlock Network code
Contact your carrier, then will unlock your phone to be used on the network. You would probably have to give some number that is associated with the phones radio signal, which they will tell you. There are some numbers behind the battery (which is behind the back cover), and in start>settings> system> device information.
SOURCE: htc diamond screen is locked and forgot code how
If you forget your password, you can hard reset or clear the device
memory. Before you do this, make sure you back up your data and files
so that you can restore them back to your device. For more information
about hard resetting the device and clearing the memory, see “Resetting
Your Device” in this chapter. See page 244
http://x.msmobiles.com/portal/images/htc/HTC-Touch-Diamond-User-Manual.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Request Help: Unlock Network code for HTC Touch Diamond
follow the instructions on this page http://forum.xda-developers.com/showthread.php?t=334679
SOURCE: where do I find the device code on a HTC Touch Diamond?
All numbers are under the battery. take the back off and take out the battery
