SOURCE: 35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Testimonial: "Hi, thank you very much for your help, I will strip the carb down and have a look. Once again, many thanks, I am very greatful"
SOURCE: ficht wont start cold,will with a jumper box,what
Check the voltage on the pink wire on the starter selonoid. Should have at least 10 volts while cranking, if voltage drops below 10V change the batteries, I had the same problem.
