Sync button won't depress
SOURCE: wii fit board blue light flashing, changed batteries and reset.
open panel on wii console and press configure button console to reset it
SOURCE: wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
SOURCE: wii fit platform does not stay switched on after
have this message came out "an error has occurred. press the eject button and remove the disc, then turn the wii console off and refer tothe wii operations manual for help troubleshooting." i tried several times, but same message pop out. izzit something do to with NTSC?
SOURCE: Wii Balance Board Lights won't stay on
Well - had the same problem, even got a walkthru from Nintendo Support. I was ready to pack it to ship off when, demonstrating everything I had done to a friend -- the darn thing started working again! I think what was going on was the sync was "poor" with the console -- it could sort of see the balance board but not enough to actually work. I did the red-button-on-the-board/ red-button-on-the-Wii thing (press board button then quickly press the console button) several times until it "took" solidly. Don't give up -- keep trying. Yeah their hardware/software has a bug......
Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
Insert a Wii Balance Board compatible game into the Wii system.
Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
Turn the Wii Balance Board upside down.
Remove the battery cover under the balance board to reveal another sync button.
Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
