Fatal error occurred, restarting
Using active sync file explorer, check to see if the file gps.txt is in the root directory, and that the file "navigator.exe" is in "VDisc/mobilenavigator" directory. If not, you will need to do a restore of Route 66 from CD then copy the file gps.txt from "Vdisk" to the root directory.... this should fix things!
Engine Initialisation error. error code 0x10005. please reinstall the application. help
Enigine Initialisation error code 0x10005 please reinstall the application
Tevion 7342. Same problem. Have tried reinstall several times but nogo. I think it is the operating system that has become corrupt.
I got a new route 66 mini and can't get gps signal. Help
I just got a new route 66 mini and can't get a gps signal. help
