I put in a 8GB SD Card and on the camara screen it says "CARD ERROR" Does the FujiFilm A800 support an 8GB SD Card? The card works fine in my laptop so I know it is OK.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
The D7160 works with SD cards. Your 8GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work with this printer. You need to use SD cards, 2GB or smaller.
The A410 works with SD cards. Your 8GB card is an SDHC card and won't work in devices not designed to use them. You need to use SD cards, 2GB and smaller.
The GR-DF570 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot it's electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
If you need a manual, you may download a copy here.
The SV-AV30 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
The E327 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible and will not work in devices not designed to accept SDHC cards. You need to use SD cards, 2GB and smaller.
The S5i uses SD cards. This means you can use microSD cards with an adapter. However, your 8GB card is actually a microSDHC card, which with the adapter appears to the camera as an SDHC card. SDHC cards are electronically incompatible with SD devices and will not work. You need to use SD and/or microSD cards, which max out at 2GB in size.
