SOURCE: CANNOT DETECT WIRELESS NETWORKS
Please type services.msc on run option
2.Please check there will be a service named as wireless zero configuration if you are using XP otherwise the third last service in vista.
3.double clisck that and then stop after restarting the machine again go to same and start it by clicking start.
4.If then also the issue is not resolved please check with your hardware vender.
SOURCE: ASUS EEE PC wireless problem
There is a great program called Network Magic that will configure your wired and wireless connections with absolute ease. ALthough it is not a free program, you can use it to sonfigure everything and after the initial 7 day (used to be 30 day) free trial, it will ask you to purchase. You can easily uninstall it through add/remove programs in Control Panel. If you choose to uninstall it, it will not undo the connections it has made, and will not leave any residual program information in your computer. You may decide to keep it though. It is a great program that will keep you informed of many network functions, as well as help with your network security. It will even tell you when others have wirelessly logged on to your network and allow you to create barriers against this. You can find it here: http://www.purenetworks.com/download/thankyou.php
SOURCE: Sony Vaio Wireless switch
if its not detected, then it is not enabled or not installed correctly..
try to reinstall the driver provide from the CDs and then enable it
thats all the problem i think
SOURCE: I bought this asus k501 on ebay and it has a
There are some things you can do. If you didn't get restore cd's with unit, you can order them from Asus. If you got cd's then boot to it and restore the system to factory. If you don't want to order cd's then go to computer store and buy an xp cd and boot to it and wipe hard drive and install xp. If the system has lots of ram then just upgrade to windows 7. you can look online for password recovery but it will cost you money and sending them the info from your system.
SOURCE: I need an instruction manual for an Asus k501
A quick internet search turned up various places to download the manual in PDF format. http://www.aeato.com/notebook/asus-k-series-notebook-detail-specification-intel-bases-and-amd-bases.html/ is one.
